1/4 ?
Old Feb 16, 2006 | 03:57 PM
Default 1/4 ?
I run 15.7@91 with a 2.3 60' in the 1/4 while a bunch of other guys are running 15.1@87ish. I'm barely slipping when I launch. I figured my slow times were due to my 3.42's, but my trap speed is higher in comparison with others. Is it just the gears or is there something wrong here?
Old Feb 16, 2006 | 04:34 PM
Tractionless's Avatar
First of all....3.42s suck.
Second, the LR4 lacks torque having only 285lbs @ 4000 rpm due to its short 3.270" stroke. That 285lbtq @ 4000rpm against a truck weighing over 2 tons = slooow out-of-the-hole. That plus shitty gears (3.42s) = even slower.
It has plenty of hp which yields you a nice MPH. The more torque, the quicker off the line, the more hp, the higher mph trough the traps. To give you an example, a 4.8 will probably take off as hard as a 4.3 L35 truck (260lbs @ 2800rpm) but it will sloughter it in the high end. (4.3 = 200hp vs. 4.8 = 270hp.)
Some lower gears or a higher rpm stall converter would definately lower your 60' hence lower ETs.
Hope this helps.
Old Feb 16, 2006 | 04:42 PM
FarmerBeau's Avatar
Sexy Party Mod
Another reason why your mph is higher is a factor of hp. You probably have more hp than the other guy running the 15.1 Good luck
Old Feb 18, 2006 | 08:36 AM
SierraSport's Avatar
My truck ran a 15.5 @ 91.2 with a 2.3 60 ft when it had K&N FPIK , and a flowmaster .. Now it is lowered 5/7 , 20" Boyd Coddington ,Hypertech HPPIII , Eaton Posi with 3.73 Gear .. I tried to run it once with all that **** , but I spun to the 330 ft and ran a 15.5 @ 93.6 with a 2.6 60 ft ..
Old Feb 18, 2006 | 09:01 AM
Colby 04's Avatar
I've got 4.11's with 31" tires, so mine takes off pretty good, but sorta falls on its face going into 3rd towards the end of the track.
walledition
Feb 24, 2026 03:27 PM
TAPyvehc93
Jan 8, 2016 10:47 AM
Chavette
Oct 28, 2015 07:33 PM
DrX
Sep 29, 2015 04:31 AM
askkmb
Sep 7, 2015 10:58 PM
