'05 GMC HVAC Sticking
Old Sep 25, 2016 | 04:26 PM
bluebird71's Avatar
Default '05 GMC HVAC Sticking
In my 05 GMC, sometimes the driver side vents will get stuck blowing fully hot or fully cold. Passenger side always works as normal, just the driver side has this issue. It's a dual climate control system. I've read threads on this before and I usually turn it off and turn the key in a certain way that resets it (for a while). I think it's about time to fix the issue, but is the root cause most likely one of the blend door actuators at the bottom of the dash or the controller itself? If it's an actuator, which one do I need to change out first?
Old Sep 25, 2016 | 06:24 PM
Wolftrk99's Avatar
The driver side blend door actuator....
Old Sep 26, 2016 | 10:23 PM
bluebird71's Avatar
But where is it located specifically?
Old Sep 26, 2016 | 10:43 PM
Wolftrk99's Avatar
Is your truck equipped with bench or buckets? Either way there is a cover that bolts to the bottom of the hvac housing, once you drop that the driver blend door actuator should be on the side of the box, and accessible fairly easily
Old Sep 26, 2016 | 11:24 PM
1994Vmax's Avatar
Pull the hvac fuses and force it to relearn... Key cycling does absolutely nothing. I have had to do it 4 times at once to get my 05 to smarten up but it does. Haven't done a blend door motor yet at 175000 miles and only usually have issues when I disconnect the battery lol.
Old Sep 27, 2016 | 08:30 PM
TrevorH's Avatar
My 05 Z71 RCSB was doing the same thing, just the driver's side vents blowing hot. I bought AC Delco part 15-72971. The blend actuator for the driver's vents are actually on the passenger's side, just above where the passenger's left foot would rest. It's about a 20 minute job.
someotherguy
Nov 15, 2018 07:59 PM
Verz
Sep 28, 2016 12:00 AM
redrdrfmx
Sep 25, 2016 07:57 PM
Choda
Sep 23, 2016 11:51 AM
fun Pain
Sep 22, 2016 09:01 AM
