04 av 5.3 help
Old Aug 9, 2011 | 10:56 AM
maverickxp's Avatar
Registered User
Default 04 av 5.3 help
OK so I lost all oil pressure the other day. I'm planning on replacing my oil pump thinking that its the culprit but are there any other things I should check first. Also do I need to lower the oil pan to remove the oil pump?
Or should I just start at the oil pickup screen?
Old Aug 9, 2011 | 12:04 PM
letsrun97z's Avatar
What were you doing when it lost psi? Any mods. How many miles. Have you checked with a mechanical gauge?
Old Aug 9, 2011 | 12:30 PM
maverickxp's Avatar
Registered User
I had just gotten off the highway. The truck is bone stock 150k miles oil pressure warning message came on in info center 2 mins later the valves started to tick
Old Aug 9, 2011 | 08:34 PM
Suburbazine's Avatar
It's possible the pickup tube o-ring just broke, or the pump could be bad. You can find out both by taking the pump off.
You need to lower the oil pan about 1" to get to the pickup tube bolt on the oil pump. Don't drop it in the pan either. If you have a 4x4 then you're in for a world of hurt, cause the front diff has to move or you have to unmount the engine to get enough clearance to drop the pan completely.
It is perfectly possible to change the pump with all the bolts taken out of a 4x4 pan though without needing to drop the axle.
I have had very good luck with taking the stock crappy pickup tube o-ring, tossing it in the trash and getting 2 new oil-safe o-rings and putting them on the pickup tube. I have gotten a little more pressure out of the pumps this way. (1 ring = 40PSI idle, 2 rings = 50-55psi idle, with 75psi at 2500rpm)
Old Aug 12, 2011 | 11:09 AM
maverickxp's Avatar
Registered User
OK so new oil pump and new red o ring. Still getting low oil pressure indicator, and lifter noise. Someone told me that a clog can form in the lifter valley and not allow oil through. Which in turn blocks the sender. .......anyone ever hear of this or fixed it?
Old Aug 12, 2011 | 02:55 PM
maverickxp's Avatar
Registered User
OK. So I'm only getting the low oil pressure indicator at idle if I Rev it up it goes away. But its still ticking....any thoughts
Old Aug 14, 2011 | 03:36 PM
maverickxp's Avatar
Registered User
Still looking for ideas. The ticking has gone away but still getting low oil pressure light at idle. I'm going to swap the sensor but I don't think that's it. Anyone ever heard of spun cam bearings or partially clogged oil galleys? On the 5.3s
maxspeed05V
Sep 23, 2015 10:48 AM
nickrench3
Sep 17, 2015 08:48 AM
OVOAustin
Sep 15, 2015 08:32 PM
11MPG
Sep 10, 2015 08:34 PM
11MPG
Sep 8, 2015 04:52 AM
