03 tahoe ac issues
Old Jul 23, 2013 | 07:41 PM
ino
Default 03 tahoe ac issues
I have my suction side at 55 and the discharge at 110 with outside air at 98. I have replaced compressor and rear expansion valve. The line going to the rear air does not get cold but some cool air comes out of rear vents. Is the rear expansion valve failed cuz the front blows cold only when driving, At a stop it blows warm in the front. I checked the fan clutch and it seems to be working and the Tahoe does not overheat. Any help or suggestions are welcomed.Thanks
Old Sep 13, 2013 | 10:42 PM
muncie21's Avatar
Sounds like you are low on charge or your orifice is clogged.
Watch the compressor when the front AC is on and the rear off (it should cycle on/off) now engage the rear. If the compressor doesn't cycle with the rear engaged, it's likely that you have a low charge.
Also, did you change the orifice tube and flush the system when you changed compressors? If not, you could have debris in the system, preventing optimal performance.
Old Sep 14, 2013 | 12:34 AM
Suburbazine's Avatar
I'd say pull a vacuum on the system then recharge with 2.7lbs of R134a. Also since you changed components you should have added between 100 and 150ml of PAG oil.
Your pressure number is very low for the high side. I generally see 230-250PSI.
Old Sep 14, 2013 | 08:07 AM
TXSZ66AVLANCHE's Avatar
Muncie21, you obviously have no idea how ac works. There is only one ac compressor....there is nothing in the rear to "engage"
Old Sep 14, 2013 | 08:08 AM
If you have a scan tool, see which sensor is turning off tbe compressor, low or hi.
Old Sep 14, 2013 | 12:45 PM
muncie21's Avatar
Sorry we can't all be genius' like yourself.
I realize there is only one compressor, by engage, I meant turn the rear AC fan on/off, which will increase/decrease the heat load applied to the system, thereby changing overall system pressures.
Old Sep 17, 2013 | 12:06 AM
RacinRust's Avatar
Idryfly5
Sep 2, 2022 08:55 PM
Knightcrawler
Jul 20, 2016 03:29 PM
mitchellmade
Sep 27, 2015 08:25 PM
Alco
Sep 4, 2015 04:08 PM
