03 Sierra p0300 code
Old Dec 15, 2014 | 10:32 PM
  #21
1FastBrick's Avatar
Custm2500's Rude Friend
Anything is possible.
Old Dec 16, 2014 | 01:25 AM
  #22
mmcguire's Avatar
Registered User
Right now I'm weighing in the option of just replacing the whole motor...for the amount of money that I've spent I could have just swapped a used one in.
Old Jan 5, 2015 | 03:17 PM
  #23
mmcguire's Avatar
Registered User
Originally Posted by mmcguire
Valve springs are good.....
I spoke with the machinist and he recommended that I pop the head off to check the head gasket. He thinks that it's broken in the spot where the two combustion chambers are closest.
I also spoke with a member on the forum (didn't get his username) and he suggested that I probably have a bad cam lobe or a stuck lifter.
Still no updates with the problem, with the holidays Ive been busy traveling and visiting family. Although I did get the valve springs back on, along with the rockers. The valves need to be adjusted still and once they get properly adjusted I'll knock out a compression test, only because I doubt the dealer did one when they said they did. Hopefully the weather holds up tomorrow after work.
How often have yall seen a bad cam lobe or a stuck lifter cause such a problem like mine?
Old Jan 5, 2015 | 03:31 PM
  #24
1FastBrick's Avatar
It is possible, but I would have to think if it wasn't pumping up you would have a specific misfire on a specific cylinder.
I would do a compression check first.
Old Jan 5, 2015 | 03:40 PM
  #25
mmcguire's Avatar
Registered User
Say it is a bad head gasket between the combustion chambers, wouldn't I still get a good reading or would it be considerably less than normal?
Old Jan 5, 2015 | 03:45 PM
  #26
mmcguire's Avatar
Registered User
And if I still had a "misfire" shouldn't I still get a code saying I have a misfire? As of right now I do not have the p0300 code and it still technically has a "misfire"
Old Jan 5, 2015 | 03:46 PM
  #27
1FastBrick's Avatar
You would see a difference as the compression escapes 1 cylinder and either enters another or enters the coolant passage.
No two mating cylinders would be at TDC on the same compresion stroke
Old Jan 5, 2015 | 03:49 PM
  #28
1FastBrick's Avatar
If its running rich it could be lighting off in the exhaust resembling a misfire.
The only way to know what's going on is to physically go through each system.
Old Jan 6, 2015 | 03:11 AM
  #29
mmcguire's Avatar
Registered User
After talking with a buddy
who was a tech at GM,he suggested that I take it back to the dealer to get real time data to see what all my sensors are saying along with fuel trims. Instead of doing that I looked around online for some diagnostic software and came across this http://www.totalcardiagnostics.com/toad/ . After reading the whole site and Amazon reviews, I decided to take the plunge and give it a try. I have the Torque app and a Bluetooth obd2 reader but it works when it wants too. I'm hoping this product will give me a little more insight to the problem before I go taking anymore parts off the motor, especially if I don't have too.
Old Jan 6, 2015 | 09:43 AM
  #30
mmcguire's Avatar
Registered User
After work this morning I was able to get some help to tighten the rockers down. Once this was complete I temp installed the coils to get this video. The flashing CEL is most likely the p0300 since when I turn the key on there is no CEL that come up, only when the motor is running.
Enjoy!
