03 Sierra p0300 code
#23
Valve springs are good.....
I spoke with the machinist and he recommended that I pop the head off to check the head gasket. He thinks that it's broken in the spot where the two combustion chambers are closest.
I also spoke with a member on the forum (didn't get his username) and he suggested that I probably have a bad cam lobe or a stuck lifter.
How often have yall seen a bad cam lobe or a stuck lifter cause such a problem like mine?
#25
Say it is a bad head gasket between the combustion chambers, wouldn't I still get a good reading or would it be considerably less than normal?
#27
No two mating cylinders would be at TDC on the same compresion stroke
#28
The only way to know what's going on is to physically go through each system.
#29
After talking with a buddy
who was a tech at GM,he suggested that I take it back to the dealer to get real time data to see what all my sensors are saying along with fuel trims. Instead of doing that I looked around online for some diagnostic software and came across this http://www.totalcardiagnostics.com/toad/ . After reading the whole site and Amazon reviews, I decided to take the plunge and give it a try. I have the Torque app and a Bluetooth obd2 reader but it works when it wants too. I'm hoping this product will give me a little more insight to the problem before I go taking anymore parts off the motor, especially if I don't have too.
#30
After work this morning I was able to get some help to tighten the rockers down. Once this was complete I temp installed the coils to get this video. The flashing CEL is most likely the p0300 since when I turn the key on there is no CEL that come up, only when the motor is running.
Enjoy!
Enjoy!
