01 water pump on a 05...
Old Aug 12, 2010 | 09:15 PM
liftedwhite94's Avatar
Default 01 water pump on a 05...
will it fit? whats the differance?
Old Aug 12, 2010 | 09:22 PM
ap2002's Avatar
Yes it fits
Old Aug 12, 2010 | 09:23 PM
okay thanks, I called autozone and they said different part number, making sure it would fit right
Old Aug 12, 2010 | 09:36 PM
qwank's Avatar
the 01 has the thermostat built into the water neck, and the 05 has a normal removable thermostat.
so you may need to buy a thermostat too if the pump you have doesnt have one
Old Aug 12, 2010 | 09:52 PM
okay thanks guys. about how much are the thermostats for the 01's? and my truck was tuned with a 160 stat but its got the stock one now, which one should I run?
Old Aug 13, 2010 | 06:53 AM
ap2002's Avatar
Double check but u should be able to used your thermostat and water neck with that pump..
Chavette
Oct 28, 2015 07:33 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Tigger Welder
Oct 1, 2015 08:41 AM
Shotguntommy
Sep 15, 2015 05:24 AM
rednekferlife101
Sep 14, 2015 05:27 PM
