00 DBC harness on 04 DBW engine?
Old May 13, 2010 | 10:05 PM
00K1500's Avatar
Default 00 DBC harness on 04 DBW engine?
Hey guys, working on rounding up the remaining parts needed for my 4.3 to 5.3 swap, just wanted to double check that I can put a 2000 model year wiring harness on my 2004 engine before I go and spend the money. Sources I've found seem to say it'll work fine, but thought better safe than sorry. Truck is a 2000 model as well..
Thanks all.
Old May 16, 2010 | 12:10 AM
brent5631's Avatar
Yeah should work fine. My oil pressure sensor had a different connector but just swapped it.
Old May 16, 2010 | 10:24 AM
DV2000NJ's Avatar
13 Second Truck Club
That's the only difference I found as well (other than the throttle body, obviously).
Old May 16, 2010 | 10:26 AM
00ChevyScott's Avatar
Wearin' da big hat
Check to make sure fuel system is the same. If it's a flex fuel motor the rails will be different and the injector plugs will also be different.
Old May 16, 2010 | 08:35 PM
00K1500's Avatar
Thanks guys, the engine is an LM4, the aluminum blocked counterpart to the LM7 so all fuel injection stuff is the same. So all I'll have to do is change the oil pressure sensor to the pre 02 one and everything else should hook right up?
ARC
57
Feb 21, 2022 10:54 AM
creekrat
Aug 2, 2015 01:27 AM
Slammed96
Jul 27, 2015 07:22 AM
85SS/85GN
Jul 22, 2015 12:48 PM
