Wet nitrous kit w/20# bottle & 3 solenoids
Old May 16, 2006 | 10:05 AM
slow96z's Avatar
Default Wet nitrous kit w/20# bottle & 3 solenoids
I pieced this kit together over the last couple of years and sold the car before I got to use it so I don't need it anymore. The 3 solenoids are all NOS brand and I have pressure tested them and they work well. I have a 4th that does not work, but could be rebuilt. You can have it if you want it.
The kit has an on/off switch, full throttle switch and fuel pressure safety switch, 2 different nozzles, 1 set of nozzle lines, 1 set of pills (I was told they are a 150 but have not checked for myself) and 2 really long bottle feed lines. I also have a bottle heater that is supposed to plug into the cigarette lighter but could be cut and hardwired wherever you want to put it.
The 20 lb bottle has been certified and fitted with a NOS high flow valve. The siphon tube was custom cut to get the last bit out of the bottle. I do not have brackets for the bottle but it would not be hard to make them. I will also throw in a 5 lb bottle with no valve if you want it. If the 20 is too big you can swap the valve to the 5.
All of these pieces are used but have been tested and work well.
$350 takes it all.
Old May 16, 2006 | 01:18 PM
ZR1 DREAMING's Avatar
want to sell the bottle seperate?
Old May 17, 2006 | 12:12 AM
negativeswitches's Avatar
i'm debating buying the whole thing going to sleep on it let you know tomorrow
Old May 19, 2006 | 09:27 AM
nonnieselman's Avatar
money will be sent today....
thanks,
Jonathan
Old May 22, 2006 | 07:35 PM
Sorry,, money is in the mail right now. Had a problem gettin to the bank to get it..
Thanks justin!!!
GXPJAY
Feb 13, 2022 08:15 AM
custm2500
Aug 22, 2015 11:46 PM
Blackrat48
Jul 12, 2015 07:28 PM
