Twin Turbo Kit For 03-07 Silverado -- T76 Turbos
$5000 plus shipping priced dropped....
* Silver Ceramic Coated Twin 10 Gauge 304 Stainless headers with T4 flanges VERY THICK
* 3” down pipes also Silver Ceramic Coated
* Two Tail 38mm Wastegates
* Percy’s Locking Exhaust Bolts and Percy’s Exhaust Gaskets
* Thermal Heat shields for the Top of the Headers
* Titanium Turbine Blankets ( carbon fiber look)
* Turbos: 4”inlets and 2.5" outlets NEW TURBONETICS T76MM TURBOS
Q-trim Exhaust with Tang. .68 Housings Journal Bearings
* Used Turbonetics Godzilla BOV
*Polished (Almost done with polishing) 4.5” Core Intercooler Size 44" x 13.5" x 5" has two 2” inlets and a single 3.5” outlet
This cooler will not fit behind the grill of the 03-07 Silverado’s since it is 4” too long. Was going to mount it underneath the front end which would minimize the cold piping.
* Polished Tall Sheetmetal Valve Covers ( These are included for the reason of plug wires and oil lines)
* Custom length Braided Oil Lines with Oil Pan Adapter for these Lines
* Coil Relocation brackets for LS1 coils
*AN-10 Oil Drains
*Taylor 10.4mm Wires ( These are not still not cut on the coil side to give you the option of where you want to mount the brackets.)
* Thermal Wire Boots
* Truck Oil Pan tapped on both sides ( not yet tried to see if it will work since it is right around where the motor mounts are)
* K&N Carbon Fiber Air Cleaners
About $600 worth of black Turbonetics silicone couplers
Things that are needed:
Cold side pipe
T-bolt clamps
*AN-10 Oil Drains
Cold side pipe
T-bolt clamps
Also if the there is a BUYER. I will also give them the option of a brand new custom Labonte Methonal S4 system with 2 PLX gauges that each will show up to 34 parameters. This is set-up in the middle console on a Carbon Fiber plate. Also a custom 2.5 gallon tank that will fit in the battery location.
