Turbo kit front mount log manifold turbonetics make and offer 99 up gm trucks
Old Jan 4, 2011 | 01:33 AM
LSXBlazer's Avatar
Default 99up GM trk Turbo kit front mount log manifold turbonetics makeoffer $2500 SHIPPED pp
Hey guys i have a turbo kit on my 2000 silverado 2wd 5.3 uses the stock manifold on the drivers side has crossover that goes in place of the Y pipe up to the back of a log manifold for the passenger side ending after the passenger side cylinders with the turbo located next to the coolant resovoir.
This kit is a direct fit for 99 up gm trucks from the hot side to the down pipe to the cold side. The down pipe is a 3 inch pipe bent to come out close to the factory exhaust pipe on the passenger side with a 3 inch v-band on the outlet and a 4 bolt flange off of the turbo. The turbo has been freshly rebuilt about 2 months ago new bearings and seals. the stock ait box can be used as a filter or i have a pipe that will direct an open element filter to where the box would normally be. charge pipe is made to come out of the turbo through the core support into the intercooler mounted directly in front of radiator. I also am including mounting bracket i made to bolt to core support. The intercooler outlet exits on the driver side going back through core support coming arounf fan shrould though a BOV and the MAF into the throttle body. The charge pipe is set up to clear a truck with a clutch style fan but will leave much more room with an electric fan set up. I am also including the oil drain line its a -10 stainless braided AN line and a oil feed line with adapter for the driver side oil block off plate drilled and tapped with a -4 an fitting and line. also comes with bigger 39lb SVO injectors, pigtails and fuel rail spacers. This kit made up to 16psi with my 5.3 setup and a very noticeable difference in power i would say 150 more on 8 psi. i never did dyno it but did race and beat several supercharged mustangs and beat quite a few ls1 camaros. In a fullsize extra cab silverado.
I am going to make a list of all parts that will come with this kit. Im looking for offers or someone to maybe tell me what its worth!
LIST:
Turbonetics 66mm turbo T4 Flange 3 inch hotside out, freshly rebuild
LOG manifold with front turbo mount/rear crossover inlet with 2.5 v-band
Stock driver side manifold
2.5" crossover with v-band on one side and stock manifold flange on ot
Turbonetics Wastegate mounted in crossover
Aftermarket BOV not sure on brand
GODSPEED intercooler 3 inch in/out dimensions 3"x 21"x 13"
intercooler mount for
all 3 inch cold side piping and couplers aluminum polished piping
3 inch to 4 inch adapter for throttle body
85mm MAF
SVO 39lb injectors with pigtails and rail spacers for truck intake
Oilf feed line with oil block off plate drilled and tapped for line
Braided Stainless -10 oil drain tube
3 inch downpipe with 4 bolt flange on turbo side 3" v-band on other
dual gauge pod made for silverado 99 and up
kit will fit 99 up GM trucks suv's, escalade, avalanche, etc 4.8,5.3,6.0,6.2 etc with slight variance in cold side piping
i think thats everything i will add more later if i have forgotten anything. I will get pics tomorrow and post them as of right now i dont have any to post. the kit is on the truck at the moment and i will also get a video of the truck running and driving with the kit on it.
Private messaege me with offers/suggestions
I can ship however it woudlnt be cheap if i did
This kit is very capable of a safe 500hp i am very pleased with it however the gas mileage on a lifted turbo truck isnt ideal for a daily driver
I will have more pictures later today fo the turbo on the truck these are just some i already had of it. the picture of the kit laing on the ground is not everything and the crossover was not complete in this picture however it is complete now with manifold flange on the driver side of it. check back in on the for sale post later today for more pictures. kit can make well over 16psi
and no lag like an sts kit!
I will entertain trades looking for a cheap s10, sonoma or a 4 wheeler and some LS parts or parts for silverado let me know what you got!
links to more pics only allowed 5
http://i780.photobucket.com/albums/y...8/IMG_0439.jpg
http://i780.photobucket.com/albums/y...8/IMG_0438.jpg
http://i780.photobucket.com/albums/y...8/IMG_0437.jpg
http://i780.photobucket.com/albums/y...8/IMG_0436.jpg
http://i780.photobucket.com/albums/y...8/IMG_0435.jpg
http://i780.photobucket.com/albums/y...8/IMG_0434.jpg
http://i780.photobucket.com/albums/y...8/IMG_0432.jpg
http://i780.photobucket.com/albums/y...8/IMG_0431.jpg
http://i780.photobucket.com/albums/y...8/IMG_0430.jpg
http://i780.photobucket.com/albums/y...8/IMG_0429.jpg
http://i780.photobucket.com/albums/y...8/IMG_0428.jpg
http://i780.photobucket.com/albums/y...8/IMG_0162.jpg
Attached Thumbnails Turbo kit front mount log manifold turbonetics make and offer 99 up gm trucks-img_0012.jpg   Turbo kit front mount log manifold turbonetics make and offer 99 up gm trucks-img_0011.jpg   Turbo kit front mount log manifold turbonetics make and offer 99 up gm trucks-img_0009.jpg   Turbo kit front mount log manifold turbonetics make and offer 99 up gm trucks-img_0435.jpg   Turbo kit front mount log manifold turbonetics make and offer 99 up gm trucks-img_0437.jpg
Old Jan 4, 2011 | 10:25 AM
javier4.8's Avatar
Can you send pics to javieru6@aol.com
Old Jan 4, 2011 | 10:46 AM
LSXBlazer's Avatar
Default pics
pictures sent!!
Old Jan 4, 2011 | 10:52 AM
LSXBlazer's Avatar
some pics are added i will add more later today
heres one pic of the intercooler on the truck
http://i780.photobucket.com/albums/y...8/IMG_0024.jpg
Old Jan 4, 2011 | 10:57 AM
iregret's Avatar
Charlie Murphy!
I'm interested. What kind of ball park figure are you thinking? How terrible was your mileage.
Old Jan 4, 2011 | 11:06 AM
LSXBlazer's Avatar
Pm'ed you!
Originally Posted by iregret
i'm interested. What kind of ball park figure are you thinking? How terrible was your mileage.
Old Jan 4, 2011 | 11:38 AM
SGP93GSX's Avatar
PM me...
I have the same questions
Old Jan 4, 2011 | 12:14 PM
LSXBlazer's Avatar
Old Jan 4, 2011 | 12:16 PM
LSXBlazer's Avatar
pm'ed you
my truck has a 6 inch lift on 35's and a cammed 5.3 got around 13-14mpg on the interstate with a heathy tune
Old Jan 4, 2011 | 04:15 PM
quicksilverado's Avatar
You need to post a price per classified rules.
