Turbo Kit, 4l65e, 317's w/ PRC springs, Cams
Old Nov 7, 2009 | 06:03 PM
sss408's Avatar
Default Turbo Kit, 4l65e, 317's w/ PRC springs, Cams
Contact: 408.luke@gmail.com or luketrueheart13@hotmail.com or PM me
I have decided to part with (almost) everything from my current build, this was going in my 2003 SS Silverado on a 4.8L motor for money reasons at the time.
OK first up Turbo kit $2800 obo (turbo & cold side not included)
Kit is for a 99+ LS"x" truck, could work on any ls motor posibly
- Trick performance custom built turbo kit
-4in Down Pipe
-Log style turbo manifold
-Crossover pipe (drivers to pass side manifold)
-Synapse 50mm wastegate (MUST STAY WITH KIT!)
-Brand New stock drivers side exhaust manifold.
-Timing Chain cover w/ oil return -8 AN port
-Synapse BOV
-Oil feed and return lines for turbo
-most clamps, gaskets, and bolts included
4l65E 4x4 Built $1000 has right under 2k break in miles on built parts and brand new rebuilt pump
317 w/ PRC .660 lift springs installed $500 (lq9/lq4/6.0 truck heads) NO MILES ON SPRINGS!!!!!! ports and machined surfaces are cleaned up
Custon Ground Cam $200 not 100% sure on specs i knows its in 250-242dur, 630ish lift 114 or 116lsa
Vibrant Silocon couplers and clamps $150
-4in-3in adapter w/ 1 4in and 1 3in clamp (ic out to ic pipe)
-3in to 3in coupler w/ 2 3in clamps (ic pipe to ic)
-3in to 2.5in coupler w/ 3in and 2.5in clamp (turbo to ic pipe)
LS2 intake Manifold $250 painted GM emerald Green
Old Nov 7, 2009 | 10:03 PM
Grumpy5.3's Avatar
probably early but woud you sell the springs seperately from the heads?
Old Nov 8, 2009 | 06:53 AM
sss408's Avatar
Not at this point no
Old Nov 8, 2009 | 07:24 PM
sss408's Avatar
BUMP! lets get some stuff sold!
Old Nov 8, 2009 | 07:51 PM
LsxCody's Avatar
Did you sell the turbo
Old Nov 8, 2009 | 08:22 PM
sss408's Avatar
yes it was the first thing to go
Old Nov 9, 2009 | 06:00 PM
sss408's Avatar
BUMP! lets move some hot parts!
Old Nov 12, 2009 | 07:25 AM
sss408's Avatar
BUMP!!! everythings out of the truck ready for shiping!
Old Nov 14, 2009 | 07:07 AM
sss408's Avatar
BUMP for the weekend!
Old Nov 15, 2009 | 11:18 AM
sss408's Avatar
BUMP! everythings out and ready to ship!
