Trick Turbo Stage III kit and more.
Old Aug 18, 2021 | 06:31 PM
TAPyvehc93's Avatar
Default Trick Turbo Stage III kit and more.
Putting my 2011 GMC Sierra 1500 extended cab truck back to stock. No trades and cash only please. I’d prefer local pickup on the big items but will ship at buyers expense. Located in Troutman, NC.
-Trick turbo stage III(less turbo)
Will include a custom turbo air intake and a custom 4” 304 stainless exhaust that connects to the downpipe with a vibrant v-band flange. It’s all tig welded and uses the factory hangers. It has a big hollow cat to pass visual inspections and a straight through magnaflow muffler that dumps before the rear axle. I also have a truck oil pan with the turbo drain fitting already installed that I will include so you wont have to drill yours. The down pipe is lava wrapped and the turbo has a nice PTP lava turbo blanket. SOLD
-75/75 Turbonetics billet wheel ceramic ball bearing turbo part # 11760-bb. SOLD
-95lb Fuel Injection Connection injectors. SOLD
-Holley fuel rails with Glennsauto performance brackets to mount on TBSS/NNBS intakes. SOLD
-Holley 1:1 boost referenced fuel pressure regulator SOLD
- MSD boost referenced programmable boost a pump SOLD
-Return style fuel pump assembly. Basically its a Walbro 450 that I made some brackets for and mounted in a gutted fuel bucket with a piece of holly hydro mat on the bottom of the pump and a -8 stainless fitting welded to the sending unit hat. The stock feed line is used as the return line. I also have the -8 Earls PTFE line and fitting that runs from the fuel tank all the way up to the engine bay with a Holley inline fuel filter mounted on the frame rail. SOLD
-FTI PML8 triple disc billet lockup 10” converter for 6l80e. Around a 3000-3200 stall on my heads/cam 5.3. SOLD
-Two piece steel driveshaft made by driveshaft specialists out in San Antonio. $400
-Dual gauge pillar for 2007-2013 trucks. $50
-AEM X-series OBDII wideband 30-0334 with a brand new sensor. SOLD
-AEM X-Series fuel pressure gauge 30-0301X. $110
-Holley valve covers with -12 fittings welded in. SOLD
-Moroso -12 dual inlet catch can breather. SOLD
If somebody wants to buy the valve covers and catch can together, I have a set of earls -12 lines and fittings made up to connect to the catch can breather. SOLD
With this setup I was able to make a easy 680RWHP on a heads/cam 5.3 running E85 and around 14.5lbs of boost.
Attached Thumbnails Trick Turbo Stage III kit and more.-27b393d5-c97e-42fb-be79-31cdb311d8aa.jpeg
Old Aug 19, 2021 | 10:04 AM
diablotruck's Avatar
Good morning. Would you do $200 on the WB/FP gauges? If not, what would you take? Paypal ready. Thank you
MG
Old Aug 20, 2021 | 10:41 AM
Blow03SS's Avatar
PM Sent on covers, can, hoses
Old Aug 20, 2021 | 11:14 AM
arthursc2's Avatar
Rails/Brackets/FPR/Flex sensor/ Lines
Is all of the above still available?
Old Aug 20, 2021 | 02:30 PM
Truckshop's Avatar
Interested in shipping that driveshaft and crossmember? 70817 is the zip.
Old Aug 21, 2021 | 07:30 AM
TAPyvehc93's Avatar
As of now, yes.
Old Aug 21, 2021 | 07:33 AM
TAPyvehc93's Avatar
I can if you cover the shipping cost.
Old Aug 21, 2021 | 08:32 AM
arthursc2's Avatar
Originally Posted by TAPyvehc93
As of now, yes.
great! I would need them shipped to 87124. I can do the estimation if you get me the size of the box, or you can estimate
if you're willing to ship, let's talk some numbers
Old Aug 22, 2021 | 07:06 PM
Truckshop's Avatar
can you get a quote?
Old Aug 23, 2021 | 04:22 PM
twistedchevy's Avatar
pm sent
