Rear Ends
Old Nov 28, 2012 | 10:41 AM
Slammed96's Avatar
Default Rear Ends
I have two rear ends I need to get rid of. One is a GM 12 bolt, has 5 lug car bolt pattern, leaf spring mount, so guessing it came out of an older muscle car. Asking $200 for it. The other is an Eaton 3/4 ton eight lug rear end, pretty sure it came out of a mid 60's early 70's 3/4 ton pickup. $350 for this one.
Both turn freely. I will not ship them because they weigh a ton, but I will deliver them within reason. (about 100 miles from either McPherson KS, or Manhattan KS)
Old Nov 28, 2012 | 11:35 AM
1FastBrick's Avatar
Custm2500's Rude Friend
FWI the truck's also had a 5 lug 12 bolt. Measure the axle to axle length. I believe the car ones were around or just under 60 inches. I believe A truck unit will be around 64 inches.
What type of 3/4 ton rear end are you trying to sell??? 12 bolt or 14 bolt?? Is it a semi float or a full floater???
Just trying to help you reach a better audience.
Old Nov 28, 2012 | 12:44 PM
Slammed96's Avatar
Measurement on the 12 bolt is about 55 inches from backing plate to backing plate, and about 43 inches from center to center on the spring mounts.
The 3/4 is an Eaton unit, I don't know much about them. Here's a picture of it for reference. Name:  1011121256.jpg
Old Nov 28, 2012 | 05:18 PM
Eaton HO72...67 to 72 Eaton HO72 rear axles were used in 3/4 and 1 ton P/U's. It has a 11.5 inch gear and is basically bullet proof. The only draw back is that only locker option is a detroit and there is only two ratios for it, a 4.57 (yes 4.57) and a 5.14 (yep 5.14). It has a full stradle mounted pinion and a adjustable thrush pad to limit ring gear deflection under severe loads too. They replaced it with the cheaper to build 14 bolt 10.5 in 73 which while itself it is a very stout axle, tough *** rear for a crawler
Old Nov 28, 2012 | 07:41 PM
Slammed96's Avatar
^this. Thank you.
pjb1972
Sep 17, 2015 02:06 PM
TimDave217
Aug 24, 2015 04:38 PM
vipergtrdj
Aug 6, 2015 10:19 PM
shupe
Aug 5, 2015 06:45 PM
Ketis
Jul 23, 2015 12:37 PM
