LQ4 pre 04 iron block based 408
**** SOLD AS SHORTBLOCK**** no cam is included, I will gladly spec you one and sell at my cost... Short block will be inspected before its shipped and buyer will get pictures of everything at that time. If there is an issue with engine it will be repaired at no cost to you, if it is un-repairable you will be refunded full amount. I don't suspect anything to be wrong with it, but it is a performance engine and has been used as intended about a dozen 1/8 mile passes, and about 1500miles of street driving. Just trying to be honest, nothing to hide.
The engine has
Compstar 4" stroke crank, 6.125 Callies Compstar rods 2.100/.927 pin, Mahle flat top pistons w/ reliefs, has total seal piston rings stainless top, iron second, 10lb oil gapped on the loose side for some boost and clevite rod/ main bearings, new dura bond cam bearings, melling high volume oil pump, arp main studs, and arp head bolts and new ls7 lifters and new plastic guides.
Engine was fresh in July I'm switching to a 6bolt deck block. And everything is getting over built. My goals are about 2khp on new setup no point in destroying a perfecly good engine
5500 shipped on a pallet to your door lower 48 states.... Still currently in truck will pull when down payment of 50% is made and ships when paid in full.
The engine has
tim wellington
Dec 30, 2015 03:59 PM
TXjeepTJ
Oct 30, 2015 08:11 PM
