K2xx Michigan Metal Works drop spindles for aluminum control arm 4wd trucks
Old May 12, 2016 | 03:30 PM
CooperS7777's Avatar
Default K2xx Michigan Metal Works drop spindles for aluminum control arm 2wd / 4wd trucks
Selling a set of MMW drop spindles for 2014+ K2XX trucks. Taylor built these for my 4wd 6.2 Sierra with aluminum control arms. My plan was to use these with a McGaughys 4/6 drop (shocks, hangers etc.) to net a 3/5 or 4/6 drop on my truck. If your using these on a 4wd truck, youll need high aftermarket CV's.
I decided to sell my truck shortly after I received these from Taylor, and they have been sitting since. These cost $1600 and had a ~6 month lead time. This is still the only option for folks with aluminum arm trucks looking to go this low.
Id like to sell these, with the McG's 3-5/4-6 kit (MMW spindles / McGs kit without spindles) for $1800 shipped.
Located in NH.
I also have McG's helper bags, brackets, and an Air Lift Wireless One compressor setup to go with this. If youd like it all, Ill take $2100 shipped.
Old May 12, 2016 | 03:53 PM
fstaslp's Avatar
how much for just the compressor?
Old May 12, 2016 | 04:01 PM
Sorry, not interested in selling the compressor setup separately. If someone wants it with the package Ill let it go, otherwise I will be using it with my new truck.
Old May 12, 2016 | 09:10 PM
shupe's Avatar
Part number on the helper bags?
Old May 12, 2016 | 10:26 PM
Three6GMC's Avatar
How are those spindles supposed to work with 4wd trucks? Those two braces in the middle are in the way of the cv shaft?
Old May 14, 2016 | 05:57 PM
You are 100% correct; I never even noticed that until you said something. I sent Taylor a message yesterday and asked, as I had requested them for my 4wd truck. He stated they will clear with aftermarket, and or high alignment CV's.
So I suppose 2wd, or 4wd with CV modification is what the description should be changed to.
Thanks!
Old May 14, 2016 | 06:30 PM
McGaughys P/N 34049/34043 on the helper bags
Drop 3/5 - 4/6 Deluxe Drop Kit W/Shocks - McGaughys Part# 34170
Old Mar 9, 2017 | 03:42 PM
Bump, 1200 for the spindles, 1500 for the whole setup.
Old Apr 1, 2017 | 01:12 AM
To the top!
HDhotrod
18
Mar 18, 2016 10:49 PM
murderedSS
Mar 14, 2016 07:22 AM
axekick
Mar 10, 2016 07:23 PM
GMCtrk
Mar 4, 2016 05:14 PM
2WDinSnow
Feb 21, 2016 11:45 AM
