Gm tech 2
Old Sep 21, 2019 | 04:16 PM
slammedchevy's Avatar
Default Gm tech 2
Got a used tech 2 works great. Cleaning out stuff I don’t need. Works from 91-2013. Scanner is used has scratches and wear but works fine. Will need to buy a gm candi adapter to use on newer vehicles. Asking 500 obo Located in Florida. For quick reply text 321 501 5675. Thanks
Old Sep 24, 2019 | 03:22 PM
Pro52R's Avatar
im sure i can just google this, but what can you do with the tech 2?
Old Sep 24, 2019 | 03:58 PM
arthursc2's Avatar
Everything from clutch position programming to ABS modulation and diagnostics
Generally speaking, if the ECM/BCM/TCM/ABS/TC can see it, the Tech2 can see it and in most cases change parameters
Very valuable for diagnostics
Old Sep 24, 2019 | 04:01 PM
Scan all systems. Do actuation tests on parts. There are certain things you can adjust in modules. Read data. You will need the candi or mdi module to get into newer vehicles but you can get that adapter for 180 on eBay
Old Sep 26, 2019 | 06:44 AM
xlcooplx's Avatar
Is this a genuine unit or a Chinese knock off? Looks to be in minimally used condition. Where did you get it from? Thanks.
Old Sep 26, 2019 | 07:01 AM
BILLY!!!!'s Avatar
You need the subscription for this, right?
Old Sep 27, 2019 | 02:59 PM
Its an actual gm one. Dealer closed down in town and got it from them. Works great. The connectors are worn that go to the obd port but it’s all cosmetic
Old Sep 27, 2019 | 03:00 PM
Not on this. It’s got software up to 13. Not sure if you can get newer cards for Later years.
Old Sep 27, 2019 | 03:05 PM
Any offers. It’s hunting season need deer money lol
Old Sep 28, 2019 | 07:29 PM
Scanner sold
slammedchevy
Aug 14, 2014 05:57 PM
FirebirdStud
Nov 10, 2010 03:42 PM
dirt track racer 81
Nov 17, 2006 07:59 AM
Chevmann99
Dec 14, 2004 09:02 PM
