FS: Trick Turbo Stage 5 kit
Old Mar 29, 2019 | 06:19 AM
ChevyThunder17's Avatar
Default FS: Trick Turbo Stage 5 kit
Selling because I spit out the transmission. Guess 12 psi WAS too much for it. The kit has about 3K miles on it. I've had the kit for awhile, just got it installed back in December of 2018. This is a complete T4 kit for the NNBS (07-13 trucks) that I had installed on my 2009 Escalade.
***In an effort to prevent you from having to drill the oil pan, something that I hated doing, I am including a Gen IV timing chain cover from ICS Billet. It was designed for a twin turbo setup, but will work fine with a single turbo setup.***
Borg Warner Turbo S400 series (upgraded 900HP+ option) - brought it to Superior Turbo in Detroit, has a clean bill of health.
5" Race intercooler
T4 Turbo blanket
Hot side pipes
Cold side pipes
Oil feed and drain lines, including the oil sandwich adapter to go in between the oil cooler flange and oil pan
BOV and WGs, with all the springs I can find
3.5" downpipe
Most of the setup has thermal wrap on it, the good DEI stuff
Weld-in MAF
Brand new ICS Billet timing chain cover (for turbo oil drain)
$4100 plus shipping. Also willing to meet up somewhere, and eliminate shipping entirely.
Pics are here; https://www.performancetrucks.net/fo...6/#post5467870
Or you can just scroll down.
Old Mar 30, 2019 | 09:07 PM
Koryvette's Avatar
Location?
Old Mar 30, 2019 | 10:00 PM
Fenton, Michigan. Just south of it, actually.
Old Apr 11, 2019 | 03:28 PM
imma_stocker's Avatar
Which turbo is that?
Did you have to relocate or delete anything?
Old Apr 11, 2019 | 03:40 PM
I *believe* it to be an 88mm, but I'll try to get measurements on it.
Did I have to delete or relocate anything? No. It comes close to the AC canister, but I bent it away by a 1/4 inch, and it is heat wrapped. So, you keep your AC. The downpipe comes close to the frame rail, but again, not a problem (never hit anything.)
Old May 10, 2019 | 04:50 PM
Ksd's Avatar
Ksd
Originally Posted by ChevyThunder17
Selling because I spit out the transmission. Guess 12 psi WAS too much for it. The kit has about 3K miles on it. I've had the kit for awhile, just got it installed back in December of 2018. This is a complete T4 kit for the NNBS (07-14 trucks) that I had installed on my 2009 Escalade. I'm also including a set of Deatschwerks 95lb/hr injectors with the kit.
Turbo (upgraded 900HP+ option)
5" Race intercooler
T4 Turbo blanket
Hot side pipes
Cold side pipes
3.5" downpipe
Weld-in MAF
Deatschwerk 95lb/hr injectors
$4100 for the kit without injectors
$4500 takes it all.
Here's a pic of it installed on the truck, I'll get more pics this weekend.
Still for sale ?
Old May 11, 2019 | 01:42 PM
Yes it is.
Old Jun 19, 2019 | 03:17 PM
Still available. Turbo rebuilt with a billet shaft.
Old Jun 19, 2019 | 06:53 PM
03sierraslt's Avatar
Billet shaft or Billet wheel? What size?
Old Jun 19, 2019 | 07:52 PM
05GMC4.8's Avatar
Willing to split the injectors from the kit? Id be interested in the injectors if so
