FS: Dedicated Fuel System and Trick Performance "P" Gauge
Old Jul 11, 2012 | 02:15 PM
krambo's Avatar
Default SOLD: Dedicated Fuel System and Trick Performance "P" Gauge
1. Dedicated Fuel System - Includes 1 gal aluminum fuel cell (anodized red), Walbro fuel pump, Aeromotive adjustable FPR (includes both High and Low pressure spring), -6AN lines / fittings and fuel line, Fuel Pressure Gauge, -6AN billet in-line fuel filter (serviceable) and FPSS (low pressure). Also includes the aux. GM battery tray so that it can be mounted in the location in the following picture. Hardly used. $600.00 SHIPPED
2. Trick performance P-gauge - NEW IN BOX. This gauge does everything. P is the only gauge in the world that is a progressive controller with mutli-point ramping capabilities. Its computer processor controls the nitrous system completely including the heater. It is the world's first and only gauge that is completely graphical and digital, with state of the art computer screen display. Its fully programmable system can work on any single stage nitrous system. You simply program the unit to your nitrous system. P is not just a gauge, it is a controller as well. P controls the heater, shuts the nitrous system down; if you are running lean or low on nitrous or fuel pressure, progressive controller, window switch, TPAS switch, nitrous pressure gauge, shift light. A warning flash will let you know you have a problem and where that problem is. P will dispaly, your (nitrous, boost, fuel, or oil pressure), O2 reading, is the heater on or off, nitrous progressive level, rpm, inside or outside the window switch setting, wot activation. The full color graphic display allows you to control and monitor your nitrous system with just a quick glance at the face. You have 8 main viewing screens to choose from, with just a push of the control button. Fits any 2 1/16 gauge pod.
• Progressive controller (time or rpm based)
• RPM window switch
• Wide-Open-Throttle detection when used with factory TPS or WOT switch.
• Supports Fly-by-Wire TPS rising or falling
• 5 Point variable Progressive ramping (time or rpm based)
• Shift Light
• Rich / Lean Cutoff (when used with a wideband)
• Air/Fuel inputs Digital or Analog
• Multiple wideband capabilities
• Heater controller
• First gear lockout / delay
• 8 different Main Viewing screens.
• Programmable Power UP screen and Arm screen
• Multiple pressure choices
• Pressure display ( Boost, Nitrous, Oil or Fuel)
Here is a good link with pictures of the gauge in action:
Trick performance guages - Nitrous Tech Forums
$300.00 Shipped to your door.
Old Jul 12, 2012 | 06:46 AM
krambo's Avatar
...responding to PM's globally: Yes I will entertain best offers.
Old Jul 13, 2012 | 12:34 PM
krambo's Avatar
Sale on both items pending. However do not be afraid to shoot offers in case they fall through!
Old Jul 13, 2012 | 01:07 PM
tonka's Avatar
Hey not gonna fit on drivers side but think it will work on passenger side just have to have battery moved to the trunk> will let you know thanks
Old Jul 14, 2012 | 11:19 AM
krambo's Avatar
No problem, make sure it fits before buying! Totally agree.
Old Jul 16, 2012 | 10:47 AM
krambo's Avatar
s o l d !
5.3lSilverado
25
Aug 29, 2016 12:48 AM
Silveradorst07
Dec 31, 2015 12:04 AM
cbhedrick
Jul 20, 2015 10:12 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
4B11T
Jul 13, 2015 03:48 PM
