FS: 6.0L Block with Forged Pistons.
Old May 26, 2016 | 09:42 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Default FS: 6.0L Block with Forged Pistons.
A 6.0L bare block that is .060 over with the 8 matching forged pistons that came from it.. They say CP on them. I have no other info except I believe they are -11cc dish. Not all shown as they need to be pulled from the rods. Will come with matching pins and clips.
$650 Local pick up near Anaheim CA.
Old May 27, 2016 | 05:32 AM
About20ninj45's Avatar
That bore makes it a 427? correct?
Old May 27, 2016 | 11:15 PM
1FastBrick's Avatar
This particular setup was used with a stock crank with a 6.125 Forged Rod.
If you use a 4.125 stroke crank with a 4.060 bore you can achieve 427 Ci
With a 4in Stroke it's a 414
Old May 29, 2016 | 08:32 PM
1FastBrick's Avatar
Someone asked If I would separate the pistons. Yes, I will Separate.
Old May 30, 2016 | 02:22 PM
1FastBrick's Avatar
Here is the pistons. Rings were only removed from 1 piston.
Old May 30, 2016 | 10:59 PM
Wolftrk99's Avatar
How long was that engine run?? The bottoms of the istons are clean as hell, tops look like they took an oil bath....
Old May 30, 2016 | 11:00 PM
1FastBrick's Avatar
About 1000 miles and 15Lbs of boost. Also had some E85 thrown at it too.
Old May 30, 2016 | 11:01 PM
Wolftrk99's Avatar
That explains that....lol
Old Jun 2, 2016 | 04:08 PM
1FastBrick's Avatar
Block Sold!!!
Still have pistons.
Old Jun 2, 2016 | 04:27 PM
Wolftrk99's Avatar
What size pistons and what you want fo them
