Front Limiting Straps
Old Sep 13, 2012 | 04:49 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Default Front Limiting Straps
SOLD!!
Need your 4x4 to hook better & launch straight every time? These WORK!
Paid $125 shipped for these a couple months ago. They have 15 passes on them. My heavy pig pulled some 1.58 and 1.59 short times with these, and it quit spinning the front tires & ended the "launch to the left" problem I was having. De-modding the truck, moving on to another project.
These are seriously heavy duty built.
$75 shipped. SOLD!!
Old Sep 13, 2012 | 04:52 PM
03regcab sierra's Avatar
Pm black bmf he needs some!
Old Sep 13, 2012 | 04:53 PM
smokeshow's Avatar
Mod with training wheels
Is this 'demodding' project what has you interested in the 149 input gear?
Old Sep 13, 2012 | 04:56 PM
No, the input gear is for a customer's truck. My truck is going back to stock, and the L33/Radix/trans are going into our Yukon. But with a bigger pulley, etc.
Old Sep 13, 2012 | 08:17 PM
idahoblkss's Avatar
Would these be the right lenth for a ss awd?
Old Sep 13, 2012 | 08:18 PM
idahoblkss's Avatar
Or can you send me a pic of them installed so i can measure it to see if they will fit?
Old Sep 13, 2012 | 08:20 PM
Most likely yes. Your truck looks about the same ride height as mine.
Get a tape measure, and measure from the bottom shock bolt to the upper shock bucket. That's how I had these mounted.
I don't have a pic of them installed, sorry.
Old Sep 13, 2012 | 08:32 PM
idahoblkss's Avatar
Looks like mine measured at around 14.5 - 15" what did yours measure at?
Old Sep 13, 2012 | 08:43 PM
Around 14" IIRC. Measuring it now wouldn't help you either, the engine/trans/etc is out of the truck, so the nose is sky high. I have "Cali lean".
If you check out the pic with the tape measure, I think they'll work just fine for you. You crank them down at the track(make them shorter), then loosen them up for the street. The double-nut(jam nut) is there to hold it wherever you set the adjustment to.
They have about an inch of stretch in them, so they are much nicer than running chains or cables.
Old Sep 13, 2012 | 09:04 PM
idahoblkss's Avatar
Pm sent!
