Bosch/FIC 72lb Injectors, Wiring Adapters, Fuel Pressure Gauge
Old Apr 23, 2015 | 10:11 PM
Ferocity02's Avatar
Default Bosch/FIC 72lb Injectors, Wiring Adapters, Fuel Pressure Gauge
Bosch injectors from Fuel Injector Connection. They flow 72 lb/hr at 58 psi, or 60 lb/hr at 43.5 psi. They are flow matched as well. These have 6 holes for better atomization. EV-14 connectors. About 53mm long from center of o-ring to center of o-ring (I think this is the LS2 length). Only about 2k miles on them so they are in great shape. I have the data sheet for these as well. FIC sells these for $560. Selling for SOLD
EV-14 to Delphi Mini (aka minitimer or Multec II) adapters. Perfect condition: SOLD
Turbosmart fuel pressure gauge, liquid filled, 1/8" NPT fitting, great condition: SOLD
Autometer fuel pressure sensor. I put this on the fuel rail and wired it into the EGR signal wires in order to log fuel pressure through EFILive. Worked beautifully. About 2k miles on the sensor. Comes with wiring. Fitting is 1/8 NPT: $70 shipped
Please PM me, thanks!
Bosch/FIC 72lb Injectors, Wiring Adapters, Fuel Pressure Gauge-ls4ysgq.jpg
Bosch/FIC 72lb Injectors, Wiring Adapters, Fuel Pressure Gauge-kcis1pc.jpg
Bosch/FIC 72lb Injectors, Wiring Adapters, Fuel Pressure Gauge-fgfq4cq.jpg
Bosch/FIC 72lb Injectors, Wiring Adapters, Fuel Pressure Gauge-25dkqbs.jpg
Bosch/FIC 72lb Injectors, Wiring Adapters, Fuel Pressure Gauge-jxjineg.jpg
Bosch/FIC 72lb Injectors, Wiring Adapters, Fuel Pressure Gauge-9g4zvgu.jpg
Bosch/FIC 72lb Injectors, Wiring Adapters, Fuel Pressure Gauge-ccl8acc.jpg
Bosch/FIC 72lb Injectors, Wiring Adapters, Fuel Pressure Gauge-fs5sdvz.jpg
Old Apr 27, 2015 | 12:35 PM
Ferocity02's Avatar
Bump!
Old May 3, 2015 | 11:23 PM
Ferocity02's Avatar
Bump!
Old May 7, 2015 | 11:21 AM
06 4.8's Avatar
PM sent
Old May 8, 2015 | 01:57 AM
Jeebalow's Avatar
PM Incoming
Old May 9, 2015 | 06:14 PM
busted33's Avatar
PM sent also
Old May 12, 2015 | 02:00 PM
06 4.8's Avatar
check your PMs
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
jrplz
Jul 9, 2015 12:07 AM
