53lb injectors for flex fuel trucks $300
Old Feb 11, 2010 | 11:58 PM
06chevy5.3's Avatar
Default 53lb injectors for flex fuel trucks $250
I have a set of injectors that are plug and play for flex fuel motors, Im upgrading to larger ones these flow 53lb at 43.5psi and almost 60lb at the stock fuel pressure they have about 8000 miles on them and are flow matched
Old Feb 12, 2010 | 10:20 AM
ERICCROLEY's Avatar
Pics? Which injector is it....
Old Feb 12, 2010 | 04:24 PM
06chevy5.3's Avatar
Fuel Injector: Siemens Mototron 109958
The fuel injectors are on the truck still I dont wana disable the truck unless I sell these. If your serious about buying them I'll take them off and take a pic, here is the site i bought them from, with a pic
http://www.fiveomotorsport.com/catal...9958_8_600.jpg
Old Feb 14, 2010 | 01:00 AM
06chevy5.3's Avatar
Bump anyone need these?
$275
Old Feb 14, 2010 | 02:51 AM
gm327's Avatar
Banned
what's the lowest?
Old Feb 14, 2010 | 03:32 AM
06chevy5.3's Avatar
Originally Posted by gm327
what's the lowest?
Price?? $275 plus shipping. They are $468 brand new
Heres a link with more info on them
http://www.fiveomotorsport.com/domes...rs/?itemid=327
Old Feb 14, 2010 | 03:47 AM
gm327's Avatar
Banned
so they fit with direct oring on gm900, how about on a ls2 intake?
Old Feb 14, 2010 | 12:21 PM
06chevy5.3's Avatar
Whay kinda motor are you putting these on?
They have the stock oring for the truck intake dont know if its the same as ls2.... The difference between these and regular truck injectors is, these are longer and have the USCAR connector, where as standard truck ones have a multech 2 and are shorties
I belive the ls2 has the USCAR connector but not sure if the height is the same or o rings. Give Five O a call and ask If these wont fit he cant tell you what to do to make them work or suggest a dirrect drop in for your application
Old Feb 15, 2010 | 12:27 PM
Doobie's Avatar
Will these fit an 03' flex fuel 5.3L connector and o-ring?
Old Feb 15, 2010 | 01:24 PM
06chevy5.3's Avatar
Yes they are a direct swap... al u need is a tune
