4L70E TBSS fully built transmission
Old Jan 21, 2008 | 05:01 PM
sprayed99's Avatar
Default 4L70E TBSS fully built transmission
fully built 4L70
transmissions parts include
Shot peened Hardened input and output shafts
Beast Sunshell
dual cage sprag
Superior Shift Kit
3/4 clutch pack: 9 clutches Alto red eagle with Koleen steels
all of the other clutches are redline material
all bushing, washers, and bearings replaced
blueprinted pump
RPM spring kit
350 lock up front stator bushing
performance separator plate
all billet pistons(no plastic)
extra wide Alto redline band
early model clutch hub with wide washer
5 pinion planets
Transmission has 0 miles
900 local pick up for trans with stock exchange
-OR-
1200 local pick up for trans. with stock exchange and phoenix 2600-2800 stall converter.
I'm located near DFW TX
Old Jan 21, 2008 | 05:04 PM
mwalls54's Avatar
Need More N2O Mod
is it a 2wd or awd?
Old Jan 21, 2008 | 09:45 PM
sprayed99's Avatar
Originally Posted by mwalls54
is it a 2wd or awd?
2WD sorry should have mentioned that
Old Jan 21, 2008 | 10:23 PM
mike06tork's Avatar
you want a tranns. with 1000 dollars or what for the tranny
Old Jan 21, 2008 | 10:42 PM
laynlow77's Avatar
still have the tbss?
Old Jan 22, 2008 | 01:00 AM
sprayed99's Avatar
yes i do
sprayed99's Avatar
???? I dont understand your post?????
Old Jan 22, 2008 | 02:29 AM
laynlow77's Avatar
you planning on keeping it? i know you got rid of alot of parts for it.
Old Jan 22, 2008 | 09:46 AM
Fallen.One05's Avatar
He doesn't know what he wants...
Old Jan 22, 2008 | 03:14 PM
bpowell688's Avatar
about how much rwhp would it hold? how does it compare to the 80e?
