2wd 4l80e Transmission
Old May 2, 2014 | 09:13 PM
Johnmaster's Avatar
MASS seller approved
Default 2wd 4l80e Transmission
This was a huge upgrade from my 4l60e. This trans has less than 1000 miles on it since being rebuilt. Pretty sure it was a '96 if I remember correct, uses only 5 of the 6 bolt holes if used on an ls like my 99 5.3. These things are rock solid transmissions. Has a transgo shift kit and some heavy duty parts installed but I forget exactly what (it was two years ago). Would like a local pick-up right now. Will consider shipping in a few weeks if I get no interested parties.
Takes months sometimes to get a transmission built up, this one is ready to abuse.
I have a driveshaft for a rclb 99 as well as a crossmember modded to fit also available. This trans turned a 11.78 one time before the motor grenaded.
Asking $1000 for the trans.
Old May 2, 2014 | 09:21 PM
Johnmaster's Avatar
Photos from before I put it in for an idea of what it looks like. Comes with shift indicator switch, rubber mount, and bung in pan for easy draining.
This is located in South eastern WI.
Attached Thumbnails 2wd 4l80e Transmission-img_0444.jpg   2wd 4l80e Transmission-img_0445.jpg
Old May 5, 2014 | 09:42 PM
Johnmaster's Avatar
Perfect replacement for your soggy 4l60e.
Old May 9, 2014 | 08:55 PM
Johnmaster's Avatar
Bump!
Old May 14, 2014 | 12:21 PM
Johnmaster's Avatar
bump!
Old May 19, 2014 | 07:46 AM
Johnmaster's Avatar
Bump!
Old May 24, 2014 | 08:08 PM
Johnmaster's Avatar
Bump!
Old May 25, 2014 | 10:24 PM
nrmskate's Avatar
Can you pm me a price on the driveshaft and crossmember shipped to 62615?
Thanks
Old May 27, 2014 | 07:10 AM
Johnmaster's Avatar
A view of the crossmember...
Old May 27, 2014 | 09:30 AM
DMarts10's Avatar
Price on the crossmember?
