03-07 Chevy/Gmc P/U turbo kit
Custom built kit for 03-07 chevy/gmc's with a 4.8, 5.3 or 6.0. This kit will only fit 2wd trucks...
PT67 with a T4 flanged .94Ar exhaust housing.
Tial 38mm wastegate.
Tial 50mm BOV
42 LBS injectors
Air to water intercooler
Lightining heat exchanger with brackets for mounting behind stock grille and circulator pump.
All couplers and clamps.
4" two piece downpipe with v band made to bolt up to stock exhaust
Custom log manifold for pass side. Uses stock drivers manifold
2.5" crossover pipe with flex joint
GM 2 bar map sensor
Gm IAT sensor
Oil feed and drain
Polished aluminum intercooler piping
New Trick performance coolant tank
All parts are ceramic coated BLACK. Has been mocked up only never ran. Turbo has about 500 miles on it. This kit just needs a fuel pump and its ready to go... Asking 2500.00 plus shipping
Tial 50mm BOV
42 LBS injectors
GM 2 bar map sensor
Gm IAT sensor
Oil feed and drain
Last edited by chevy2ls1; Apr 8, 2009 at 08:53 PM. Reason: price change and new parts
