Zex.. Which kit?
Old Dec 15, 2010 | 09:28 PM
09sierra6.2's Avatar
Default Zex.. Which kit?
ive got a 09 gmc sierra with the 6.2.. i see a kit for trucks up to 6.0's but idk if it ill work for my truck. would the camaro system work better for my truck? since its made for the 6.2? NEW to bottle feeding so be gentle! lol
Old Dec 15, 2010 | 11:47 PM
walledition's Avatar
I have a zex kit and it works ok, I didn't know better when I bought it, I would recomend u nitrous outlet instead zex, just my opinion
Good luck with that 6.2, I wish I had that motor
Old Dec 16, 2010 | 12:30 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Just to help you out, the nitrous kit doesn't have any idea what it's hooked up to. It sprays nitrous and fuel at WOT. That's all it does. Jetting and tuning is up to you.
That said, a 6.0 kit should go on a 6.2.
Old Dec 16, 2010 | 12:33 AM
viciousknid's Avatar
Where's the Beef?
The only difference in a car kit and a truck kit that I could think of would be the length of the main line. But I'm sure both would include plenty.
Old Dec 16, 2010 | 08:58 AM
ok thanks for that but should i go dry or wet? and also if its a plate kit it would matter on the truck one bc of throttle body size unless the 6.0 has the big 92mm i think it is? not sure tho thats why im asking.. and what about safeness? lol i mean ive seen nitrous backfires and thats what scares me being my DAILY DRIVER!!
Old Dec 16, 2010 | 09:20 AM
if im not mistaken zex only has plates for carburetor, im using a zex kit with a nitrous outlet plate
Old Dec 16, 2010 | 09:23 AM
well by plate im mean throttle body spacer with the lines plumbed in it.. now i just seen a zex kit setup that way before havnt went and looked at the kits that close so they may not come with it but i knew some did that ive seen wether they were zex or not idk but i was told the zex kit was one of the best to get... open to many ideas tho need to learn as much as i can before i go thru with this! not wanting to spray over 100 shot tho, thats enough to make a hella difference and not to much to be greedy with a stock internals
Old Dec 16, 2010 | 09:29 AM
i know what you mean and i don't think zex has a plate kit that fits your truck, only carburetor, if u wanna stay with zex u would have to use a nozzle in your intake, i might be wrong but back when i bought mine there was no plate available for my truck
Old Dec 16, 2010 | 09:34 AM
dang well may look at nitrous outlet then.. i really wana make it so i can remove as easy and keep it if i ever get rid of it.. whats your take on wet or dry system?
