Z71 Tahoe out of commision....
Old Feb 3, 2003 | 08:05 PM
z71tahoe's Avatar
Default Z71 Tahoe out of commision....
#7 cylinder only has 75psi in cylinder test- I need a new engine? with 15,000 miles on the clock what should I do?
Any suggestions would be great. Does anyone know how to do the 6.0 swap? Who sells a tricked out 6.0l motor? Or 5.3? How much?
Thanks-
Old Feb 3, 2003 | 08:53 PM
jlwz71's Avatar
Default Re: Z71 Tahoe out of commision....
Damn, what happened? <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Old Feb 3, 2003 | 09:20 PM
GMC SKI's Avatar
Sorry to hear about the Dreaded #7cylinder ..
You have tonnes of options with a rebuild you could forge out the bottme end on it and crank up the boost on that baby
you could do a 6L swap which is realtivly easy from what i understand
well what it boils down to is how much Cash do you have to throw at it ?
is it your daily driver ?
If it is streetablity would be a concern and going to radical on a rebuild/ new engine might not help
Either way you'll need a copy of LS1 edit to tune anything you put in.
There are lots of good engine builders to your right all depends on time and money you have
Keep us posted on what you end up doing.
good luck
Jim
Old Feb 3, 2003 | 09:47 PM
XLR8NSS's Avatar
Adkoonerstrator
Damn #7 cylinder. Alot of the problems you hear about are with #7. I wonder if it's some sort of problem with the intake design?
Jim pretty much summed things up. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
John
Old Feb 3, 2003 | 09:54 PM
z71tahoe's Avatar
I will probably replace the motor next week. I will let you now what happens- If anyone can recommend a good deal on a factory replacement motor that would be great-
I am also selling the supercharger- 1750 delivered.
Old Feb 4, 2003 | 08:16 AM
BigTex's Avatar
Ben, sending you another PM.
Old Feb 5, 2003 | 12:29 AM
lm7's Avatar
lm7
what kind of supercharger do you have?
Avalanche2002
Nov 30, 2015 07:31 AM
cheyenne383
Nov 13, 2015 09:24 AM
Infernohoe
48
Oct 2, 2015 10:25 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
lxcoupe
Sep 23, 2015 12:11 AM
