Z06 Injectors
Old Apr 24, 2003 | 07:32 AM
Scream's Avatar
MOOBIES Moderator
Default Z06 Injectors
My buddy is getting ready to upgrade the injectors in his Z06. Are his stock ones any better than the truck injectors? Are they even the same style injector? Should I try to take them off of his hands?
Old Apr 24, 2003 | 10:48 AM
Hit Man X's Avatar
Default Re: Z06 Injectors
The stock Z06 flow more than the truck ones, but not by a ton. The Z06 are about 28lbs/hr.
They won't work without mods to your fuel rail. His are shorter and have a different plug.
If you need a set, go with a set of Bosch design III injectors for your application. The fuel rail will need to be shimmed about 5/8" and you will have to splice in the correct plug ends. A PITA if you don't need the extra flow.
Old Apr 24, 2003 | 11:09 AM
Scream's Avatar
MOOBIES Moderator
Thanks for the info. I don't need the extra flow now, but I thought that I might if I decided to spray it! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Apr 24, 2003 | 02:18 PM
Hit Man X's Avatar
I'd say a 100 shot dry or less and the stock injectors will be fine. I'd be more worried about the fuel pump before the injectors going static.
Pimpinpete
43
Dec 22, 2017 08:13 AM
shootermwc
Oct 8, 2015 01:45 PM
sTNT971
Sep 26, 2015 04:22 PM
OHsixLS3
Sep 25, 2015 11:20 AM
Closer_2001
Sep 7, 2015 09:40 PM
