youve got to be kidding me...
Old Jul 18, 2013 | 12:42 AM
lsx_production's Avatar
also i would like the largest streetable cam....thinking about a 3600 stall as well
Old Jul 18, 2013 | 05:27 AM
beastmode's Avatar
Import Moderator
You purchase the smaller V8 engine in the heaviest cab configuration and you're surprised it's slow... did you bother to test drive?
Old Jul 18, 2013 | 06:47 AM
abey15's Avatar
4.56 gears, a 3600 stall, a tsp220 or tr220 cam and the rest of the bolt ons will make u a lot happier! Then a good custom tune and u will once again blow your tires off! Good luck man!
Old Jul 18, 2013 | 12:07 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
And if it doesn't, throw a 100 shot at it!
Old Jul 18, 2013 | 08:07 PM
GREENSIERRA's Avatar
this, wont be 12s but it will put a smile on your face
Old Jul 18, 2013 | 09:01 PM
zero2sixT's Avatar
Dont do this. If you want 12s, forced induction is the best bang for the buck. Even going to a stock ly6 would be a much, much better option than running a large cam/converter in a 4.8. You are about to open a huge can of worms trying to put a cc with a 4.8 in the 12s running natrually aspirated.
If you want a dependable truck, that is fun to drive, tune/converter is the way to go. It will be a night and day difference.
Old Jul 18, 2013 | 09:13 PM
craigsix's Avatar
check my public profile on my 5.3 i got into the 13s with stock cam and only a 2.08 60 ft.
Old Jul 18, 2013 | 11:08 PM
gonzo 6.2's Avatar
keep it stock save your money save your warrenty.Save your $ for your next truck and buy biggest engine availible for your cab configuration
Old Jul 18, 2013 | 11:12 PM
gonzo 6.2's Avatar
you should put this in your sig.
im ready to hit the track finally.this truck project has taken alot longer to get ready than my car projects in the past. got my truck in july. its a 2012 rcsb ls worktruck 5.3 6speed. mods are knn drop in airraid tube ported & polished 90mm tb fast lsxrt 102mm slp udp kooks longtubes w catted ypipe into 3inch by 18inch summit glasspack with turndown before axle. 1.8 yella terra ultralite rockers circled 3000-3200 278mm stall 4.10 richmond accel gears tuned by area 47.
What did you spend to get there?
Old Jul 18, 2013 | 11:50 PM
gamble686's Avatar
You want 12s in a 4.8L crewcab? Hmmmm
You need spray forced induction or a bigger motor to get 12s in a 2010 crewcab.
Solid build to get you there....
Isky triple twelve cam contact stock4.8
Circle d 3400 stall
4.10s
Trick turbo kit stage 3.
Fuel system to support big power.
Custom tune
Weight reduction
