Yet another 5.3 to 6.0 swap thread
Old 07-09-2014, 10:35 PM
  #21
Flyin 1500's Avatar
Originally Posted by Hulign
Hope you don't mind a few questions?
Are you using the standard 8.1 injectors or the marine injectors?
Using the fuel rails from the tbss intake?
What size/brand is the throttle body?
Will be curious to hear how it idles?
Thanks!
Standard 8.1L injectors with Nelson Tune...which arrived in the mail today! Woot!!! Fuel rails and intake and TB from stock 00 5.3l silverado. I will video the idle when I fire it hopefully Friday. Stay tuned!
Old 07-09-2014, 10:37 PM
  #22
Flyin 1500's Avatar
Originally Posted by catman3516
does the IPA come with the motor,or was it xtra lol
Extra unfortunately, but if you like IPA I highly recommend it. I'm sure it's waaaaaay better out of the tap, but in the bottle it's still pretty friggin good! Cheers!
Old 07-09-2014, 10:44 PM
  #23
Hulign's Avatar
Stock parts!?!?! Don't let my wife hear that. I'm lucky the LS in the S10 has brought her over to the dark side.
Any plan to dyno?
Old 07-09-2014, 10:50 PM
  #24
Hulign's Avatar
My schedule isn't helping me in my project. I noticed a weird shift or two the other day on the drive home from work so will be farming out the transmission/stall install on Monday. Don't want to tear up the stocker cause it goes straight in for a rebuild. Haven't ordered the motor yet. Want to get all the suspension drop parts and brakes thrown on first. The kid is driving the spare truck. Once she starts college next month I can tear it apart.
Old 07-10-2014, 09:53 AM
  #25
gagliano7's Avatar
Do you no the cam specs and what springs they used? I can't wait to see how this thing runs. Good luck.
Old 07-10-2014, 11:56 AM
  #26
Flyin 1500's Avatar
It's a Howards cam with Duration 269 / 278
Duration @ 50 216 / 224
Lift 551 / 551
LSA 114
110 CL
No idea about the springs other than they are not stock.
Old 07-11-2014, 05:19 AM
  #27
gagliano7's Avatar
Thanks for the info that should be a nice driver.
Old 07-13-2014, 06:45 PM
  #28
Hulign's Avatar
Hopefully you are busy racking up those break in miles!
Looking forward to the review.
Old 07-13-2014, 09:20 PM
  #29
Flyin 1500's Avatar
Sadly I'm not. Got everything installed friday and hooked the battery up and the starter engaged. Pretty sure the solenoid is bad, or I have two wires touching....but I had to go to work, so I won't be able to get back into it until tomorrow.
Old 07-13-2014, 09:50 PM
  #30
Hulign's Avatar
Hope it's something simple!
My transmission/stall is going in tomorrow (trans did some weird things last week so decided to swap before it strands me. Upper control arms will be here Weds. Will do the pump while the bed is off to do the C notch. Dropping it 4/6. Need to order the pump from racetronics.. Stocker is taking a crap. Can't drive it much till I get the trans cooler bolted in. Will also do the bigger brakes while I'm there. Haven't decided on exhaust yet. Thinking I want full 3" duals with an x pipe but might be overkill. Also not sure on pipe clearance with rear drop.
Waiting on your thoughts before I order the motor....
Also looking at a Blueprint Engines 427 supposed to be 625hp. They are about 2 hours from me.
Sorry for the long rant... Starting to get pumped for my build.
Quick Reply: Yet another 5.3 to 6.0 swap thread
