yes or no on fuel return
Old Jul 4, 2010 | 03:54 PM
dragpac's Avatar
Default yes or no on fuel return
my 91
ss454 has a carb and external fuel pump and regulator and off the regulator is a return to the tank.can I block the return to the tank and do away with it?or do I need it.it still has the stock gas tank.I want to get rid of it if I can because the fuel pump runs constantly.
Old Jul 4, 2010 | 04:59 PM
JoeyGC5's Avatar
If you block the return the regulator will not fucntion correctly, b/c the diaphram can't control the line pressure as it was designed.
Old Jul 4, 2010 | 07:49 PM
dragpac's Avatar
even on a after market regulator?
Old Jul 5, 2010 | 08:32 PM
dragpac's Avatar
I removed the fuel return and replaced the regulator and I'm back in buisness.6 1/2lbs fuel pressure.
Sevex
Aug 22, 2015 12:12 AM
Jake75
Aug 21, 2015 09:13 AM
TAPyvehc93
Aug 8, 2015 06:35 PM
GMCtrk
Jul 17, 2015 06:39 PM
