Yank TCvs Stock TC to Flywheel alignment..
Old Mar 7, 2004 | 11:40 AM
OBXMarine's Avatar
Default Yank TCvs Stock TC to Flywheel alignment..
Quick question before I get too far along, does the Yank TT300 TC bolt up using the same holes used by the stock converter? I would imagine so, but from eyballing it, it doesn't look like the mounting orientation between the TC's are identical.
Thanks again!
Old Mar 7, 2004 | 12:04 PM
1TRUESS's Avatar
I sure hope so!
Old Mar 7, 2004 | 12:05 PM
OBXMarine's Avatar
Originally Posted by 02Silverado
I sure hope so!
LOL
Old Mar 7, 2004 | 12:17 PM
1TRUESS's Avatar
Damn it OBX! Your install is making me nervous!
Old Mar 7, 2004 | 03:21 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
I didn't have any trouble at all putting in my TT3000.
Old Mar 7, 2004 | 03:23 PM
Flyer's Avatar
They line up just fine ... I wasn't the one under there doing that part, I had the easy part of turning the crank, but I don't remember any cussing about that part.
Be sure to get the right size allen heads though. If you have the wrong size they will strip out.
Old Mar 8, 2004 | 07:36 PM
OBXMarine's Avatar
They'll line up just fine. You may have to rotate the TC and flexplate a few times to get it right, but 1 out of 3 aren't bad odds. Have lots of tranny fluid. At least 6 quarts.
Old Mar 8, 2004 | 07:46 PM
Flyer's Avatar
I take it you got the converter in there alright ?
Old Mar 8, 2004 | 09:11 PM
OBXMarine's Avatar
Yes Sir!!! As you can tell by my new Avatar.
Old Mar 8, 2004 | 11:54 PM
sleepersilverado's Avatar
the only thing you should have to look for is the space between the flywheel and the cpnverter pegs. i believe if there is more than a 3/16"-1/4" gap you need to shim it.
