Yank 2600 stall
Get the Yank 3000 the drivability is excellent with good tires and a posi it can knock about .5sec off your 1/4mile time it has full towing ability and you'll kick yourself for not buying the 3000,when you feel the difference the 2600 makes.
I just installed a yank 2600 and transgo shift kit last weekend. I too was worried about drivability. I'm very happy with the 2600. It drives almost like stock. After driving it a week I don't even notice it.
The truck still creeps forward when in gear just not as fast as stock. Rpm's hang around 1500-1800 or so when driving "normal". It will foot brake to around 2000rpm. I think the only time it will see "flash" to 2600 is with sticky tires from a stop.
With that said, The yank 3000 would probably also drive just as good. If I was NA or if I was planning on racing at the track more with slicks I would have went with the 3000 for sure. With the 2600 it gives my street tires a chance to hook right before the boost comes on hard.
Banned
I have the PTC 2600 it will flash with MT drag radials to about 3200 it only goes to 2500 on foot brake I have haul trucks and all with this TC.I work over an hour way from home and I have not had a problem yet love it but you know it is in there it is nocicable.But works put down a 1.64 60' with my truck.
Originally Posted by dust6928
what have you guys seen different with mpg during normal driving?
at 1st mine went down. i used to get 125-150 miles with 3/4 tank left
then i went to 100-125 with 3/4 tank left
now it has gone back up. go figure
