y pipe vs x pipe
Old Feb 5, 2016 | 08:44 AM
Alco's Avatar
Default y pipe vs x pipe
What do you guys run and for what reason ? I'm looking to buy speed engineering headers and wondering if it's worth the hassle to build an x pipe setup instead of the y pipe they offer?
The truck is staying n/a this year with upgraded intake manifold but next year I have the lsa blower laying in the corner of my garage
Old Feb 5, 2016 | 01:04 PM
TXsilverado's Avatar
For no specific reason i run y pipe on 5.3 engines and duals w x on 5.7 and larger. No dyno evidece for all combos... Just what i do. I gained good power on 5.7 and larger by stepping up to larger primaries and duals. I just dont see a na 5.3 needing that much exhaust.
Old Feb 5, 2016 | 02:07 PM
03sierraslt's Avatar
I think it comes down to total exhaust volume more then anything. If you have duals then X and a Y if you have single. I run dual 3" into single 4" and really like it.
Old Feb 5, 2016 | 08:37 PM
Alco's Avatar
And with the lsa blower what would you do?
Old Feb 5, 2016 | 08:40 PM
Alco's Avatar
the plan is to have a side exit with twin tips before the rear right wheel so 3 " all the way would do the job
Old Feb 5, 2016 | 11:13 PM
Wolftrk99's Avatar
I ran 2.5" ss/denali duals on my ecsb to an h pipe i made (which in all reality is probably too far from the engine to be of any real purpose) i am about to rework it for long tubes with an xpipe about where my cat pipes connect to the extension pipes...... If i ever go the lsa route like i keep daydreaming about, i will probably go to a 3inch dual setup, not that i think it really needs it...
Old Feb 6, 2016 | 01:10 AM
Blown06's Avatar
8 Second Truck Club
Put the biggest ******* exhaust possible on it.
Old Feb 6, 2016 | 02:40 AM
5.3 can use the bigger exhaust at that point.
Old Feb 6, 2016 | 06:39 AM
Alco's Avatar
I plan on going 1 3/4 primary unless you strongly sugest 1 7/8
Old Feb 6, 2016 | 11:27 AM
terravast4's Avatar
i run 3" duals through x pipe and xr-1 race mufflers
