Y pipe
Old Jun 21, 2005 | 11:17 PM
white1's Avatar
Default Y pipe
Will I see any signifigant gains using a Flowmaster Y pipe and gutted cats (with a straight pipe thru them) on factory manifolds, or should I wait till I can save up for LT's? I'm power hungry. And impatient.
Old Jun 22, 2005 | 09:12 AM
01Blackerado's Avatar
Wait till I get my Magnaflow on and I go to the track...Its going o as we speak and Im going to the track tonight if if turns my SES code off. If not then I'll be at the track next week after i replace the rear o2
Old Jun 22, 2005 | 10:24 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
You wont see anything significant but it should give you better top end though. With lts' and no cats you should see atleast a 20hp gain at the wheels.
Old Jun 22, 2005 | 10:27 AM
I dont now about 20HP at the wheels but I will say I've seen personally 12HP
Old Jun 22, 2005 | 01:58 PM
02sierraz71_5.3's Avatar
I am running a flowmaster y and I got some u bends and welded up a y pipe from the stock manifolds to the flowmaster, then into my 3". I did this before the lt's I noticed more of a difference from getting rid of the cats and crappy stock ypipe than I did from the lt's.
If I had to guess I would say at least a 25 rwhp gain it was unbelievable just from redoing the ypipe.
Dont gut the cats just chop the ******* off and weld up a y into the flowmaster collector. You will gain alot more than you think
Old Jun 22, 2005 | 04:52 PM
yackowski's Avatar
Switching from dual Flowmaster 40 series, to a catless- Pacesetter- magnaflow setup, I noticed a very significant SOTP gain down low as well as up top!
Old Jun 23, 2005 | 07:10 AM
white1's Avatar
Thanks for the info, so ditch the cats, and use the Flowmaster Y and I'll notice some good gains huh? Sounds good what size Y 2.5 to 3??
03sierraslt
14
Oct 9, 2015 05:53 AM
JordanH
Oct 3, 2015 03:59 PM
BlownHD
Oct 3, 2015 12:24 PM
JordanH
Sep 12, 2015 12:02 AM
sTNT971
Sep 11, 2015 02:38 AM
