Wrong spark plug gap possibly....
Old Nov 11, 2008 | 11:18 AM
BlackGMC's Avatar
Resident Retard
weird...ill keep my .060.
i think so too, but when i put in tr-55s in my truck gapped at .55 it ran like crap... Talked to a knowledgable tuner, he said that i would have to increase the dwell time a little bit to compensate for the larger gap... I just put the stockers back in rather than screwing with a table i know nothing about...
Old Nov 11, 2008 | 11:25 AM
budhayes3's Avatar
PT's Slowest Truck
i run my ngk tr55 at .060 with OEM plug wires.
when i pulled my factory spark plugs they said acdelco and NGK.
does anyone know why they reduced the plug gap specs in 03-04????
It's due to the iridium plugs, I don't know the exact science behind it, but iridium plugs generally have a smaller gap, and usually come pre-gapped since it's so easy to break the tips off of them. You can't gap iridium plugs the old way where you pry between the ground and the electrode, you have to grab the ground only, or the tiny iridium tip may break off.
Old Nov 11, 2008 | 11:30 AM
TXsilverado's Avatar
thats how i gap my non-irridiums...a bench vice. i dont like touching the electrode thingy. it just doesnt seem right haha.
Old Nov 11, 2008 | 11:37 AM
budhayes3's Avatar
PT's Slowest Truck
Yea, it's best not to pry against the electrode on any kind of spark plug. I usually use needle nose pliers
Old Nov 11, 2008 | 05:04 PM
04RST's Avatar
I checked the gap on my old plugs that i pulled out, they we're gapped to .055, the same as the ngks i put in. On a brighter note, when pulling off my wires to check all their connections, 2 pulled apart right at the plug, one on each side. I'm hoping they were already torn, causing the problem. Running on 6cyl could be the reason why it felt sluggish.
twake_410
Apr 14, 2016 09:58 PM
bearden86
26
Nov 15, 2015 03:58 PM
KleanKustoms
Sep 30, 2015 05:07 PM
trxmxzx
Sep 29, 2015 07:42 AM
Gadgetized
117
Sep 27, 2015 10:28 AM
