would dual Bosch 044s in the tank be too much
Yes series = one after another. Parallel = side by side separate supply separate feeds.
Is hooking two 044s in parallel going to do what for me? I'm after the volume more than I am the pressure.
I never understood running pumps in series; you are still always restricted by the volume the pump can flow. Just now it sees a lower pressure so it flows slightly more, but not near the same as twice the pumps flow at the higher pressure like in a parallel setup. If you want volume, do them in parallel.
im doing a surge tank setup with dual 044's are we speak, will turn out to be a KILLER once its done, thats a promise LOL but Im still debating the whole dual pumps vs one single pump, so if it fails I know. This way if one pump fails ill probably lean out and blow something up.
lxcoupe
Sep 6, 2017 08:24 AM
