is it worth it?
Old Apr 25, 2009 | 07:12 PM
Brandon511's Avatar
Default is it worth it?
I have a 05 gmc sieera with a 4.8l .the 4.8l is gutless,well the 35 inch tires dont help and 342 gears, would swapping in a 5.3 be worth it? I have a brute force intake with a gibson catback exhaust,i planned on doing a nelson tune and some long tube headers and swapping gears with 4.56 gears,but is this all worth it, or just start with the 5.3l and then add these upgrades? Thanks
Old Apr 25, 2009 | 07:15 PM
dlt76028's Avatar
swapping from a 4.8 to a 5.3 is not worth it. do the 4.56s first, then look into a radix superchager.
Old Apr 25, 2009 | 07:22 PM
viciousknid's Avatar
Where's the Beef?
If you swap. swap to a 6.0.
Old Apr 25, 2009 | 07:28 PM
RST's Avatar
RST
cam,gears,sts and a tune.
Old Apr 25, 2009 | 08:02 PM
Brandon511's Avatar
okay i will try this stuff first.what about a vette servo can you tell me what i need and where to get one
Old Apr 25, 2009 | 08:48 PM
vista4.8's Avatar
http://www.oregonperformancetransmis...de=NTP-K51828C
Its easy to install.
Old Apr 25, 2009 | 08:58 PM
m3srt's Avatar
Banned
instead of going and putting a **** load of money in a little 4.8 u may as well go get a 6.0 ...
if ur gonna mod it 4.8 is NOT the way to go no matter how much money u put in it
Old Apr 25, 2009 | 09:08 PM
that's not talking any ****...
Old Apr 25, 2009 | 09:14 PM
To the op, I would do gears a tune and some long tubes you had the right idea. It should wake it up. I give props to those who did swaps, but sometimes there are other alternatives and it's all up to you.
Old Apr 25, 2009 | 11:22 PM
PathfinderJr's Avatar
Any mod you do with a 4.8 can eventually swap over to the 6.0 so what difference does it make.
Off the top of my head, the only quasi-normal mod that I can think of that would be different for the two different engines would be what cam to slide in, but swapping cams to sell the old one is cake. There's always someone willing to buy a cam kit.
As long as super huge expensive heads aren't slapped on, you're good to go with most bolt-ons.
