wont start! NEED HELP!!!!
could be the motor is blown, maybe the pcm is bad, maybe the cam chain broke and locked up the crank shaft. the fuel pump relay could have melted a pin, could have melted the ingition 1 and 2 fuse symontatiously. possibly a cat got in the beltsand as you tried to start it it locked the motor up. could have ran out of oil and the 2nd main bearing from the front welded to the crank shaft. possibly had the wrong key in the ignition .seriously dude it could be a million things..give more detail
muncie21
Sep 7, 2015 09:55 PM
