wont start! NEED HELP!!!!
Old Aug 16, 2008 | 12:21 AM
Biggin's Avatar
Default wont start! NEED HELP!!!!
when i try to start my truck i does nothing
Old Aug 16, 2008 | 12:28 AM
dirt track racer 81's Avatar
could be the motor is blown, maybe the pcm is bad, maybe the cam chain broke and locked up the crank shaft. the fuel pump relay could have melted a pin, could have melted the ingition 1 and 2 fuse symontatiously. possibly a cat got in the beltsand as you tried to start it it locked the motor up. could have ran out of oil and the 2nd main bearing from the front welded to the crank shaft. possibly had the wrong key in the ignition .seriously dude it could be a million things..give more detail
Old Aug 16, 2008 | 02:18 AM
2 tone 02's Avatar
Are you sure it was your truck? My neighbor's truck is the same color as mine and I see where that could get confusing!
Old Aug 16, 2008 | 05:49 AM
viciousknid's Avatar
Where's the Beef?
I started rolling before I even got to the 2nd post
The first thing i thought was "Needs some gas in it" in the voice of Carl from Slingblade.
Old Aug 16, 2008 | 01:08 PM
budhayes3's Avatar
PT's Slowest Truck
Check your battery...
flatblack83
Jan 3, 2026 07:10 PM
Texas5.3_1251
Mar 5, 2016 08:10 PM
11MPG
Sep 10, 2015 08:34 PM
muncie21
Sep 7, 2015 09:55 PM
mayko
Sep 7, 2015 12:24 PM
