Won't start first try
Old 11-17-2016, 08:08 PM
85LSburb's Avatar
Default Won't start first try
I have a 01 Silverado with a 5.3 that looses fuel pressure with key off. Takes a few key cycles for pressure to build. I have pulled the vacuum line off the regulator and no fuel is in the line. The fuel pressure jumps to 58 with the line off. As soon as you shut the key off the pressure drops from 50ish to 0 in about 5 seconds. Any ideas?
Old 11-17-2016, 08:49 PM
FFDP's Avatar
Bad regulator.
It doesn't have to **** fuel out to still be bad. If it can't hold the pressure, it's the first thing on my list to change.
I wouldn't think it's a check ball in the tank/pump if these trucks even have them.
Old 11-18-2016, 11:17 AM
Custm2500's Rude Friend
1FastBrick's Avatar
It could also be the line on the pump inside the tank.
Mine developed a pinhole leak that was obvious when I pulled the pump for replacement.
Old 11-18-2016, 06:44 PM
Mine used to do that so I replaced the pump assembly.
Old 11-18-2016, 06:46 PM
85LSburb's Avatar
Thanks guys. I'm just gonna replace the pump and regulator. It has over 200k on it.
Old 11-18-2016, 06:48 PM
1FastBrick's Avatar
Good call with that kind of mileage.
Old 11-18-2016, 10:41 PM
Wolftrk99's Avatar
My 99 has done it the same thing to me at least 3 times and every time it has been the pump. i never really got i to figuring out why it was happening, but there were too many other issues all pump assembly related; inaccurate fuel level signal, delayed start, and random loss of pressure. I had one pump that was providing just enough pressure for the truck to run, never thrpugh a lean code either at the end of that one's life i wasgetting ridiculously good fuel mileage....then i changed it
