Wiring harness compatability
Old Jan 12, 2009 | 09:05 PM
Tamatt27's Avatar
Default Wiring harness compatability
I've got an '05 LM7 that's DBW. The engine harness was cut, however, at ths PCM. I've got a engine harness from a '99 iron-head LQ4 that's cable-operated TB. That's not a problem, since I'm going with an LS6 intake with cable TB for my '66 'Stang. Will the older wiring harness work with the newer engine? Which PCM should I get?
Old Jan 13, 2009 | 07:45 PM
Tamatt27's Avatar
Bump...
Old Jan 13, 2009 | 09:33 PM
budhayes3's Avatar
PT's Slowest Truck
The engine and harness will work together, but I'd get a PCM from an 01-02 to work with it. The 03+ PCM's are drive by wire, and 99-00 PCM's work on a different operating system that isn't as good as the 01-02 OS, from what I've read. I do believe that the 01-02 OS can be flashed into a 99-00 PCM though, if need be, but I'm not 100% sure.
Old Jan 14, 2009 | 06:31 PM
Tamatt27's Avatar
Cool! Thanks man.
Texas5.3_1251
Mar 5, 2016 08:10 PM
SLOPONY
11
Sep 24, 2015 02:47 PM
Silver8ado
Sep 14, 2015 06:35 PM
spooneralmighty
Sep 11, 2015 02:28 PM
muncie21
Sep 7, 2015 09:55 PM
