Will a TC mess with HPP3 tuning?
Old Jan 4, 2004 | 06:23 PM
StreetSweepa's Avatar
Default Will a TC mess with HPP3 tuning?
I was just wondering if a torque converter would mess up HPP3 programming. There is an option for aftermarket gears and i'm planning on going with 3.73's and a yank 3000. Should i worry about the programming messin up?
Old Jan 4, 2004 | 06:35 PM
KeukaZ71's Avatar
i have all those mods and have not had a problem yet, KOW
Old Jan 4, 2004 | 08:16 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
I don't know, but I have a situation in which I'm wondering the same thing.
Before the stall, I set my HPP3 for a rev limit of 6200RPMs, and the 1-2 shift I set at 6000RPMs. While it did read 6000RPMs on the 1-2 shift, after I got my stall in I also got EFI Live and began logging.
What I realized was that the RPMs were actually higher than what my tach showed, and the reason I would hit the rev limiter sometimes when I would do a WOT burnout and then 1-2 shift.
My tach would read 6000, but on EFI Live it read 6200...I think it even went up to 6300 or more.
Since I didn't get EFI Live until after my stall was put in, I have no idea if it was because of the stall or whatever.
So I set the 1-2 shift to +3 and it is ok, while it shows 5800-5900ish 1-2 shifts, it's probably around 6000ish now. I will log tomorrow and see what it is, then probably take it down another notch and log again...
Old Jan 5, 2004 | 01:35 AM
FLASH's Avatar
chingon let us know where exactly you set your shift points because i am in the same boat as you are.
Noah Burns
Dec 30, 2015 12:06 PM
06 4.8
Aug 21, 2015 11:33 PM
therock
Aug 20, 2015 02:31 PM
Suburbazine
Aug 9, 2015 01:17 AM
lxcoupe
Jul 14, 2015 10:14 PM
