will a complete ls3 drop in to my truck?
Old Sep 18, 2011 | 01:32 PM
bolikes2skate's Avatar
Default will a complete ls3 drop in to my truck?
will a 100% complete ls3 drop into my truck? pretty much will the 4l60e and wire harness work n everything? the truck in my sig
Old Sep 18, 2011 | 04:14 PM
andrew383's Avatar
traveling mod
Yes...BUT you'll need the knock sensor harness(moved from valley cover to side of block) and cam sensor ext harness (moved from top rear to front cover)
Besides that stuff a retune..Nothin major..
Old Sep 18, 2011 | 04:17 PM
LS1TRUCKGUY's Avatar
And a 24x to 58x reluctor conversion module
Old Sep 18, 2011 | 04:33 PM
andrew383's Avatar
traveling mod
Oh yeah had a brain fart on that
Also Lingenfelter sells all 3 harness's
Old Sep 18, 2011 | 05:19 PM
iamkeniff's Avatar
your 58x to 24x box has long enough wires to take care of that for you so no need for that harness. also why pay 55.00 for a harness when all you have to do is cut/solder/shrink wrap you factory knock sensor harness to reach the side of the blocks. 10 min worth of work to save 50.00 i think id take that challenge. also you have to drill the side of the block with a 11/32 and use a 10mm 1.5 tap to be able to thread in your old knock sensors. also you will have to delete the VVT if you plan to go with another cam. swap over your ACC from your truck too. you will also need a 4 bolt 90mm DBC throttle body bc your intake setup will not swap over.
The_W
Oct 28, 2015 09:00 PM
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
Deceptarado
Jul 8, 2015 05:24 PM
