Wideband bung location
I am in the process of installing new exhaust and was wondering where to install the Wide band bung for the sensor? I have a X pipe after the headers. There are no cats anymore and the x pipe is on the passenger side of the truck. Is there a better place for it or will that work? Thanks!
Why would you want it on only one side and not both? You would think you would want to read off of both like on a X pipe or something. Just curious as to why just the driver side. Thanks.
Becuase number 7 cyl is the one that always goes BOOM.. And number 7 is on the driver side.. If both banks are operating the same the AFR's from both banks should be close...
Hmmm, good point...I was thinking that the best place would be somewhere that you could read both banks also, like smack dab in the middle of the x-pipe if that's possible. I guess that the driver's side makes sense now though...
I thought you would want to take readings from both sides, the whole thing compared to just one side. I guess that if that number 7 is a problem it does make sense to take readings from that side.
That would be optimal, but I'm not sure how many wideband can run 2 different sensors so you may be stuck with buying 2 different setups which gets expensive.
gmcyukon
Oct 3, 2015 11:03 PM
jscherbs
Sep 30, 2015 07:54 AM
