wide band???
Old Aug 21, 2003 | 09:49 PM
bigguy75inches's Avatar
Default wide band???
hey guys,,, i finially just have to ask. What is a wideband and how does it help me, how much is it, and where can i get it? i do have ls1 edit and a off brand version of a-tap.
Old Aug 21, 2003 | 10:25 PM
BigTex's Avatar
Default Re: wide band???
A wideband is an O2 (oxygen) sensor. The stock truck O2 sensors only work accutately in a certain air / fuel ratio. A wideband O2 accurately reads air / fuel in a much wider band of mix. This makes it an invaluable tuning tool. http://www.widebando2.com/FAQ_1.htm
If you buy one, you'll use your LS1 edit for tuning. It won't be much help on a near stock truck, but the more mods, the better you can get your truck running with one. It really helps tuning a major internal engine change as well as forced induction and nitrous.
A popular brand is the FJO unit. Parish8 has one, as well as several others. http://www.fjoracing.com/
Old Aug 21, 2003 | 10:42 PM
what is the pricing and what exactly do i need.. all i found on the websight was a package deal that was around $3,000!
Old Aug 22, 2003 | 12:20 AM
hohl's Avatar
Check these guys out http://wbo2.com/ they just released a new kit that uses a $28 O2 sensor instead of the $200+ one most kits use. I think you can get the whole 2.0 kit from these guys for about $400.
Old Aug 22, 2003 | 07:20 AM
creederado's Avatar
How about this?
http://www.innovatemotorsports.com/
Old Aug 22, 2003 | 09:39 AM
do i need just the sensor or just the whole kit???
does my factory wiring harness plug into the new sensor?
Old Aug 22, 2003 | 10:49 AM
hohl's Avatar
You will need the whole kit. Wideband O2's produce voltage between 0-5 while our stock O2's are only 0-1 volts.
It looks like you can hook up the wideband kit to your factory wiring harness in order to have the wideband AFR and provide the ECM with the proper signal 0-1 volts.
"Using the analog outputs, the LM-1X can be programmed to modify/condition the AFR/Lambda data normally used by an ECU (Engine Control Unit) to determine fuel injection curves. With the included LMD (dash-mountable display), the user can also monitor AFR and Lambda in real time." - http://www.innovatemotorsports.com/lm1x.php
Old Aug 22, 2003 | 06:04 PM
hohl's Avatar
creederado,
you know anyone with one of the innovative widebands? I read some really good stuff about it and am thinking about getting one.
The designer, Kraus, was answering questions on a Subaru Impreza board.
Old Aug 22, 2003 | 06:43 PM
creederado's Avatar
Nope, I just have been seeing it around more and more.
Seems pretty strait forward for the average tuner. I'm sure someone here will get one before fall.
Old Aug 23, 2003 | 02:30 PM
Procharged LM7's Avatar
see my post here regarding the Innovate Sam
https://ls1tech.com/threads/showflat...rue#Post675243
