Why factory low compression?
Old 04-08-2023, 02:36 AM
woodwright's Avatar
Default Why factory low compression?
So school me on something I've always wondered. Why do the car manufacturers produce engines with lower compression? What's the benefit? With these LS engines it seems you can run them up to almost 12:1 on pump gas with more power and better mpg. So why not build them that way to start with?
swathdiver (04-08-2023)
Old 04-08-2023, 09:50 AM
DuNnO
RDF1's Avatar
Which manufactures?
You can run a 13.5CR LS on 87 octane if you wanted to. Just run colder plug and lower timing.
Old 04-08-2023, 01:10 PM
swathdiver's Avatar
Emissions and the variations in gasoline quality are my best guess.
Old 04-08-2023, 05:23 PM
makes children cry
_zebra's Avatar
most people're too cheap to run higher octane gas & make use of those added benefits.
even our H3 has 10:1 SCR and is advertised as made for 87... but it uses the variable exhaust cam timing to reduce DCR on top of running less ignition timing.
Old 04-22-2023, 07:11 AM
YukonJack's Avatar
All of the above, or……they know a bunch of delinquents are gonna jam some boost into them?
07NBSChevy
05-17-2016 01:29 AM
teamblackandred
07-28-2012 06:40 PM
whyt00
05-24-2011 06:24 PM
ihdude
06-06-2009 09:41 PM
joshua022
12-16-2007 08:20 PM
Quick Reply: Why factory low compression?
