Compression and Pump Gas
It really depends on the entire setup, it's the Dynamic Compression Ratio that really counts. You could have high Static compression, but with a bunch of intake duration on the cam, your dynamic compression ratio will be lower and pump gas won't be a problem. I've seen dynamic compression ratio calculators on the net...
Even to compare the octane needs of a Ford to a Chevy wouldn't be of any value.
The point is, bigger bore, bottom-end power cams, and less efficient combustion chambers all require more octane.
I hear 11.5-1 is possable with a ls-6 cam, but the tuning has got to be forgiving and a touch rich.
My 4.8 has a 9-1 and from everyone I talked to is very forgiving of lots of timing, heat, and variences of life. I don't see why a 10-1 wouldn't be the same way if a guy had a good tune on his truck with enough gear so the truck turns 2000rpm on the freeway, and doesn't load up big when he tows.
My truck is about 10.7:1 and i have run premium usually, but have also tried 87 with a little less timing and it didn't pick up any kr, i have been running e85 lately, with my compression, and a little more timing i break even on cost of fuel, but i use it because it smells 10 times better with no cats than gas does.
