Why does it start like this???
Old Mar 3, 2005 | 12:52 AM
NeverSatisfied02's Avatar
ok, thanks all!! I will check the fuel pressure and go from there!
Old Mar 10, 2005 | 12:33 AM
graystepside's Avatar
I had the same problem with mine over the summer. turned out to be the cat converter. the one on the drivers side was broken up on the inside. listen for a knocking noise, like a rock rattling around in the exhaust. we thought it was the fuel pump, changed the filter, checked the fuel pressure and it turned out to be the cats.
Old Mar 10, 2005 | 03:56 AM
gametech's Avatar
My friend has an SS that would die at idle that turned out to be some gunk built up on the throttle blades. No idea how it got there.
Old Mar 10, 2005 | 06:59 AM
crazy3gz's Avatar
Easy way to tell if it's the pump is to try to "prime" it. Turn the key on and let it sit for a couple seconds, you'll normally hear the pump kick on. Turn key off, then do it again. Do that like two or three times, then try to start it. If it starts right up it's the pump. Also, once it's started, if you turn it off, will it do the same thing? or start right up? Usually it's the check valve in the pump, it'll start back up once it's running but once it sits it lets the pressure bleed off.
Old Mar 10, 2005 | 08:17 AM
01Blackerado's Avatar
If for some reason that isnt the case...which i dont think it wouldnt be, what octane fuel are you running!? Just something to think about if you use 87 or lower
flatblack83
Jan 3, 2026 07:10 PM
Texas5.3_1251
Mar 5, 2016 08:10 PM
11MPG
Sep 10, 2015 08:34 PM
muncie21
Sep 7, 2015 09:55 PM
mayko
Sep 7, 2015 12:24 PM
